Results 1 to 8 of 8
Thread: 160. Lighter fix for darker problems (shorts tip)
    Supporting Member Make Things's Avatar
    Dec 2018
    Midwest, USA
    Make Things's Tools
  2. The Following 7 Users Say Thank You to Make Things For This Useful Post:
    Hoosiersmoker (Jun 1, 2023), johncg (Jun 1, 2023), nova_robotics (May 31, 2023), piper184 (Jun 1, 2023), rlm98253 (May 31, 2023), Toolmaker51 (May 31, 2023), verticalmurph (Jun 1, 2023)
    Sep 2018
    nova_robotics's Tools
    I have one of those mechanical pencils. It's closer to a mechanical crayon. Whatever it writes with works well with metals too.
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Yeah, the website (amazon) says that it's chalk...but if it is, it's mixed with something that pretty much makes it into more of a crayon. Little disappointing...it's not as easy as I had thought it would be to wipe off (when I purchased it). Dab spit on your finger and it cleans up pretty quickly though. I would imagine it would be great for all sorts of things (leather as well)...but metal would definitely be a plus as graphite doesn't do much of anything when you use it. I'll keep your tip to use it on metal in my mind...I've always used sharpies, but of course those leave thick lines.
    Thanks for saying something!
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    What about the silver streak pencil which is popular for metals? I’m guessing it works fine on wood but maybe isn’t so easy to clean/remove and I don’t know if it leaves residue behind when it comes time to add a finish.
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Quote Originally Posted by thevillageinn View Post
    I just looked them up...I didn't know they made a mechanical variety. I should get one. Any idea how thick the 'leads' are?
    Sep 2018
    These ones? I just measured about 2.4mm "lead" diameter.
    160. Lighter fix for darker problems (shorts tip)-img_20230609_112204558.jpg
  8. #7
    Dec 2018
    Midwest, USA
    Make Things's Tools
    Dang! Hey...I used that pencil on a piece of steel. Absolutely amazing. You were spot on!
  9. #8
    Jul 2017
    2.4mm sounds about right, because I think there are other pencils which use a similar size “lead”. I haven’t tried interchanging the silver streak “leads” with graphite in different holders like a drafting pencil.
