Results 1 to 4 of 4
Thread: 1919 AJS Rebuild
    olderdan's Tools
    1919 AJS Rebuild
    I had to make 4 new valve covers as the originals are beyond use. Made from chrome moly steel and milled on my lathe vertical slide, indexing was done by a large hex nut located into the top recess against a parallel to the rear (good enough for spanner flats) and nickel plated.
    Also the carburettor bore has been lapped and a new brass slide made, all polished and nickel plated.
    Should be able to get the engine buttoned up soon.
    1919 AJS Rebuild-carb.jpg1919 AJS Rebuild-carb-2.jpg1919 AJS Rebuild-carb-3.jpg
  2. The Following 3 Users Say Thank You to olderdan For This Useful Post:
    baja (Jun 10, 2022), ChasT (Jun 9, 2022), tonyfoale (Jun 10, 2022)
    Aug 2012
    Australia
    desbromilow's Tools
    well done!!!!
  4. The Following User Says Thank You to desbromilow For This Useful Post:
    olderdan (Jun 10, 2022)
    What are the numbers for near the top of the carb? Mixture or throttle stop adjustment?
  6. The Following User Says Thank You to tonyfoale For This Useful Post:
    olderdan's Tools
    Hi Tony
    The carburettor is an AMAC single jet type fitted from 1914 to 1920. A very basic device which took a lot of research to understand it. The numbered ring at the top is an air control adjustment which can be altered by lifting the knurled ring and rotated to the next peg inside, there is no throttle stop other than the cable setting. The knurled ring turned black during the plating as I did not realise it was aluminium.
