Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 41
Thread: 1963 used engine oil disposal article - photo
Hybrid View
    Popular Science article on how to properly dispose used engine oil.
    Homemade waste oil burner - video
    Spill free oil change using dipstick - GIF
  2. The Following 5 Users Say Thank You to Altair For This Useful Post:
    12L14 (Jan 28, 2021), durrelltn (Apr 24, 2022), jimfols (Jan 28, 2021), nova_robotics (Jan 28, 2021), Scotty1 (Jan 28, 2021)
    12L14's Avatar
    Aug 2017
    12L14's Tools
    Not sure about engine oil, but diesel is - unfortunely - highly biodegradable...
    Lake Tahoe
    IntheGroove's Tools
    I remember having neighbours in the 60's that did that...
    Supporting Member rlm98253's Avatar
    Not a good idea in 1963. Still not a good idea in 2021.
  6. The Following 2 Users Say Thank You to rlm98253 For This Useful Post:
    Philip Davies (Jan 29, 2021), Tonyg (Jul 13, 2024)
    Supporting Member jimfols's Avatar
    Sep 2015
    Ontario Calif USA
    That is funny
    Jim
    nova_robotics's Tools
    Seems like good advice.
    Supporting Member TrickieDickie's Avatar
    Jun 2018
    Louisiana
    My dad would slosh it on the gravel drive way to the house. I don't remember everything from my childhood but I do not recall any disposal/recycling centers. I am sure vehicle repair shops at that time had means of disposal but my dad would not bother.
  10. #8
    hotdog0627's Avatar
    Jul 2016
    hotdog0627's Tools
    Any ideas on how to repurpose used oil?
  11. #9
    Quote Originally Posted by hotdog0627 View Post
    Run it through a paper filter. Works great for heating your shop.
  12. The Following User Says Thank You to nova_robotics For This Useful Post:
    hotdog0627 (Jan 30, 2021)
  13. #10
    I installed a waste oil fired boiler, with radiant floor heat distribution, for an excavating contractor. His shop generates hundreds of gallons of used oil each year. He also collects used oil from many other business contacted he has. The burner will handle anything from #2 diesel to heavy gear lube. Burns clean with no smoke or smell. It does create enough ask to require cleaning the combustion chamber and heat exchanger every 1000 hours. The burner has disposed of coming up on 7000 gallons of far. The EPA tried to shutdown waste oil burning a few years ago, but it has proven to be less polluting that the re-refining process. https://www.energylogic.com/waste-oil-boilers/el-375b/
    As far as recycling, oil does not wear out, it just gets contaminated with byproducts of combustion and the additives get depleted. So it is easy to re-refine into good oil again. Transportation costs to the few refineries that exist make it not cost effective in many parts of the country. Companies that transport the oil charge shops to pick it up, then charge the refinery for delivery. We used to have a re-refiner here in central Ohio, but they kept blowing blowing themselves up and having large spills. They finally went out of business due to fines and costs of rebuilding. https://www.dispatch.com/article/201...NEWS/306039907
    Pouring it into the ground is a bad idea. Letting it soak into the ground keeps the air and microbes away and it will eventually contaminate ground water. Left exposed to air, like a spill on the surface, it will biodegrade over time. They used to spray it on country roads to hold down dust.
    It is crazy some of the things we used to do to get rid of things we no longer want. How many remember bathroom wall cabinet with the razor blade disposal slot in the back?
  14. The Following User Says Thank You to hemmjo For This Useful Post:
    nova_robotics (Jan 30, 2021)
