Results 1 to 10 of 322
Thread: 1974 XS/TX650 rebuild
    Oct 2015
    th62's Tools
    Finished off the rear carb mounts and anodised them. The brackets that attach to the carbs were brush finished prior to anodising, whereas the larger brackets was polished prior to anodising, so the finish is slightly different. Everything fits and works as intended, but it's very tight in there. The manifolds sit the carbs 10 mm behind the taps, so I had to swap the taps so the outlets faced forward. The small brackets attach to the larger bracket via a grommet and positive stop T nut, the larger bracket bolts to the front of the battery carrier which is rubber mounted. I also spun up a couple of brass 6mm to 8mm brash fuel line adapters.
ID:	41489   Click image for larger version.
ID:	41490   Click image for larger version.
ID:	41491   Click image for larger version.
ID:	41492   Click image for larger version.
  2. The Following 2 Users Say Thank You to th62 For This Useful Post:
    asterix (Jan 7, 2022), Rikk (Jan 7, 2022)
