Results 1 to 10 of 322
Thread: 1974 XS/TX650 rebuild
    Oct 2015
    th62's Tools
    As you are probably aware, when fuel runs low in bike tanks tank, due to the tunnel one carb can run dry, BS carbs overcome that problem by linking the carbs via a short hose between them. I run VM carbs on the TX so there is no fuel link. Previously I had a jumble of hoses and T piece barbs linking the petcocks, but that was just so untidy, so today I made a fuel distributor. Not quite finished yet: I still have to drill the linking gallery through so the petcocks are linked, but, I don't have a 4.5mm drill long enough, so I'll have to drill from both sides and blank one side off with a screw and copper washer, then punch in three brass barbs, clean it up a little, round off the edges and polish it.
    The distributor mounts underneath the front lip of the ally battery carrier I made some time ago.. A tube from each petcock attaches to the two inner barbs via a small filter, fuel line links the two outer barbs to the carbs.
    I was going to make one with integral sintered bronze filters, but the unit would have been LARGE , so I decided to go with the two inline filters.
    The left side works well, plenty of room for the hoses and filter as the carb hose attaches to the side of the distributor, but the right side is a little crowded as the fuel inlet on the carb is on the same side as the left hand carb, I may have to make another just a few mm wider.
    I'm going into hospital today for five days, that'll be followed by about of month sitting on my bum, so it'll have to wait a while before I can finish it off.
ID:	43306   Click image for larger version.
ID:	43307   Click image for larger version.
ID:	43308   Click image for larger version.
ID:	43309   Click image for larger version.
ID:	43311   Click image for larger version.
ID:	43312   Click image for larger version.
  2. The Following 3 Users Say Thank You to th62 For This Useful Post:
    greenie (Jul 24, 2022), nova_robotics (Jul 25, 2022), tonyfoale (Jul 25, 2022)
