22 Best Homemade Tools from ADVRider.com
The excellent forum at ADVRider.com creates some very useful homemade motorcycle tools builds.
ADVRider.com is currently tied at #19 on our list of homemade tools sites, with 170 homemade tools built by ADVRider.com members (to see them all, check out: 170 homemade tools built by ADVRider.com members).
Here's our pick of the 22 best homemade tools from the ADVRider.com forum:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/tire-bead-breaker-3"><img src="/uploads/43944/tire-bead-breaker-3.jpeg" alt="Tire Bead Breaker"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/tire-bead-breaker-3">Tire Bead Breaker</a>
<span> by <a href="/builder/victor441">victor441</a></span>
</div>
<div class="tags">tags: <a href="/tag/bead-breaker">bead breaker</a>, <a href="/tag/welding">welding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/pressure-bleeder-4"><img src="/uploads/44268/pressure-bleeder-4.jpeg" alt="Pressure Bleeder"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/pressure-bleeder-4">Pressure Bleeder</a>
<span> by <a href="/builder/fritzcoinc">fritzcoinc</a></span>
</div>
<div class="tags">tags: <a href="/tag/brake-bleeding">brake bleeding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/motorcycle-lift-stand"><img src="/uploads/44280/motorcycle-lift-stand.jpeg" alt="Motorcycle Lift Stand"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/motorcycle-lift-stand">Motorcycle Lift Stand</a>
<span> by <a href="/builder/kubiak">kubiak</a></span>
</div>
<div class="tags">tags: <a href="/tag/stand">stand</a>, <a href="/tag/lifting">lifting</a>, <a href="/tag/welding">welding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/motorcycle-tire-changer-2"><img src="/uploads/45660/motorcycle-tire-changer-2.jpeg" alt="Motorcycle Tire Changer"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/motorcycle-tire-changer-2">Motorcycle Tire Changer</a>
<span> by <a href="/builder/MCMXCIVRS">MCMXCIVRS</a></span>
</div>
<div class="tags">tags: <a href="/tag/tire">tire</a>, <a href="/tag/welding">welding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/mechanic-s-toolbox"><img src="/uploads/46660/mechanic-s-toolbox.jpeg" alt="Mechanic\'s Toolbox"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/mechanic-s-toolbox">Mechanic's Toolbox</a>
<span> by <a href="/builder/1994klr250">1994klr250</a></span>
</div>
<div class="tags">tags: <a href="/tag/toolbox">toolbox</a>, <a href="/tag/welding">welding</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/screw-and-bolt-keeper"><img src="/uploads/46884/screw-and-bolt-keeper.jpeg" alt="Screw and Bolt Keeper"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/screw-and-bolt-keeper">Screw and Bolt Keeper</a>
<span> by <a href="/builder/groundrules">groundrules</a></span>
</div>
<div class="tags">tags: <a href="/tag/disassembly">disassembly</a>, <a href="/tag/keeper">keeper</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/motorcycle-jumper-cables"><img src="/uploads/48548/motorcycle-jumper-cables.jpeg" alt="Motorcycle Jumper Cables"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/motorcycle-jumper-cables">Motorcycle Jumper Cables</a>
<span> by <a href="/builder/klm4755">klm4755</a></span>
</div>
<div class="tags">tags: <a href="/tag/jumper-cables">jumper cables</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/nut-starter"><img src="/uploads/49104/nut-starter.jpeg" alt="Nut Starter"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/nut-starter">Nut Starter</a>
<span> by <a href="/builder/KLboxeR">KLboxeR</a></span>
</div>
<div class="tags">tags: <a href="/tag/assembly">assembly</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/rotary-tool-6"><img src="/uploads/74080/rotary-tool-6.jpeg" alt="Rotary Tool"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/rotary-tool-6">Rotary Tool</a>
<span> by <a href="/builder/"></a></span>
</div>
<div class="tags">tags: <a href="/tag/handle">handle</a>, <a href="/tag/cable">cable</a>, <a href="/tag/rotary-tool">rotary tool</a>, <a href="/tag/collet">collet</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/motorcycle-wheel-balancer-3"><img src="/uploads/84844/motorcycle-wheel-balancer-3.jpeg" alt="Motorcycle Wheel Balancer"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/motorcycle-wheel-balancer-3">Motorcycle Wheel Balancer</a>
<span> by <a href="/builder/trokel">trokel</a></span>
</div>
<div class="tags">tags: <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/wheel">wheel</a>, <a href="/tag/welding">welding</a>, <a href="/tag/balancing">balancing</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/vacuum-pump-7"><img src="/uploads/85240/vacuum-pump-7.jpeg" alt="Vacuum Pump"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/vacuum-pump-7">Vacuum Pump</a>
<span> by <a href="/builder/Luke_3">Luke</a></span>
</div>
<div class="tags">tags: <a href="/tag/suspension">suspension</a>, <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/vacuum">vacuum</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/sidecar-lift"><img src="/uploads/84808/sidecar-lift.jpeg" alt="Sidecar Lift"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/sidecar-lift">Sidecar Lift</a>
<span> by <a href="/builder/CCjon">CCjon</a></span>
</div>
<div class="tags">tags: <a href="/tag/floor-jack">floor jack</a>, <a href="/tag/jack-stand">jack stand</a>, <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/lifting">lifting</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/shop-elevator"><img src="/uploads/84824/shop-elevator.jpeg" alt="Shop Elevator"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/shop-elevator">Shop Elevator</a>
<span> by <a href="/builder/jbhawley">jbhawley</a></span>
</div>
<div class="tags">tags: <a href="/tag/cable">cable</a>, <a href="/tag/lifting">lifting</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/motorcycle-lift-16"><img src="/uploads/84852/motorcycle-lift-16.jpeg" alt="Motorcycle Lift"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/motorcycle-lift-16">Motorcycle Lift</a>
<span> by <a href="/builder/Ricardo+Kuhn">Ricardo Kuhn</a></span>
</div>
<div class="tags">tags: <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/lifting">lifting</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/wheel-balancer-5"><img src="/uploads/85168/wheel-balancer-5.jpeg" alt="Wheel Balancer"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/wheel-balancer-5">Wheel Balancer</a>
<span> by <a href="/builder/Tim+McKittrick">Tim McKittrick</a></span>
</div>
<div class="tags">tags: <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/wheel">wheel</a>, <a href="/tag/balancing">balancing</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/boot-and-glove-dryer"><img src="/uploads/85188/boot-and-glove-dryer.jpeg" alt="Boot and Glove Dryer"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/boot-and-glove-dryer">Boot and Glove Dryer</a>
<span> by <a href="/builder/catimann">catimann</a></span>
</div>
<div class="tags">tags: <a href="/tag/gloves">gloves</a>, <a href="/tag/dryer">dryer</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/gps-logger"><img src="/uploads/84804/gps-logger.jpeg" alt="GPS Logger"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/gps-logger">GPS Logger</a>
<span> by <a href="/builder/zozie">zozie</a></span>
</div>
<div class="tags">tags: <a href="/tag/arduino">Arduino</a>, <a href="/tag/electronics">electronics</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/motorcycle-lift-19"><img src="/uploads/90804/motorcycle-lift-19.jpeg" alt="Motorcycle Lift"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/motorcycle-lift-19">Motorcycle Lift</a>
<span> by <a href="/builder/kenstone">kenstone</a></span>
</div>
<div class="tags">tags: <a href="/tag/lifting">lifting</a>, <a href="/tag/winch">winch</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/motorcycle-tire-mounting-method"><img src="/uploads/98644/motorcycle-tire-mounting-method.jpeg" alt="Motorcycle Tire Mounting Method"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/motorcycle-tire-mounting-method">Motorcycle Tire Mounting Method</a>
<span> by <a href="/builder/Poolside">Poolside</a></span>
</div>
<div class="tags">tags: <a href="/tag/tire">tire</a>, <a href="/tag/wheel">wheel</a>, <a href="/tag/assembly">assembly</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/tire-changing-stand-4"><img src="/uploads/111064/tire-changing-stand-4.jpeg" alt="Tire Changing Stand"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/tire-changing-stand-4">Tire Changing Stand</a>
<span> by <a href="/builder/Smola67">Smola67</a></span>
</div>
<div class="tags">tags: <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/tire">tire</a>, <a href="/tag/disassembly">disassembly</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/90-degree-screwdriver"><img src="/uploads/116346/90-degree-screwdriver.jpeg" alt="90 Degree Screwdriver"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/90-degree-screwdriver">90 Degree Screwdriver</a>
<span> by <a href="/builder/otpipe">otpipe</a></span>
</div>
<div class="tags">tags: <a href="/tag/screwdriver">screwdriver</a>, <a href="/tag/angle">angle</a>, <a href="/tag/gears">gears</a></div>
</div>
</div>
<div class="bimg">
<div>
<a href="https://www.homemadetools.net/mobile-work-table"><img src="/uploads/116338/mobile-work-table.jpeg" alt="Mobile Work Table"></a>
</div>
</div>
<div class="title">
<a href="https://www.homemadetools.net/mobile-work-table">Mobile Work Table</a>
<span> by <a href="/builder/kyrbz">kyrbz</a></span>
</div>
<div class="tags">tags: <a href="/tag/motorcycle">motorcycle</a>, <a href="/tag/portable">portable</a>, <a href="/tag/workbench">workbench</a>, <a href="/tag/casters">caster(s)</a></div>
</div>
</div>
</div>
