Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: 27 Speeds External Headstock Gearbox (Free Plans and More)
    Jan 2016
    Dubrovnik, Croatia
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    LMMasterMariner's Tools
    W A R N I N G / W A R N I N G / W A R N I N G / W A R N I N G / W A R N I N G / W A R N I N G / W A R N I N G / W A R N I N G /
    ONE MISTAKE FOUND.
    AND CORRECTED.
    CHECK CORRECTIONS.pdf
    DIDN'T HAVE THIS PROBLEM IN PREVIOUS VERSION (18 SPEEDS) AS THERE WERE 60 TEETH AND 64 TEETH GEARS IN THE SAME LINE
    AND WITH COPY / PASTE USED IN DRAWINGS, WELL S...T HAPPENS.
    Attached Files Attached Files
  2. The Following 3 Users Say Thank You to LMMasterMariner For This Useful Post:
    Frank S (08-28-2018), Jon (08-28-2018), PJs (08-28-2018)
  3. #12
    Jan 2016
    Dubrovnik, Croatia
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by kquiggle View Post
    Thanks for making your work available. Do you have any videos of the gearbox in action?
    yes, check http://www.homemadetools.net/forum/h...-gearbox-67608
  4. The Following User Says Thank You to LMMasterMariner For This Useful Post:
  5. #13
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PJs's Tools
    Thank You LMMasterMariner for sharing all of this with the community and throughout your journey. Most Impressive!! Quite the Amazing build and design journey you took to the finish line. Loved the video compilation and the music was perfect imho! Was that gear setting accordion, paper or metal...looked like metal reduced and formed??
    Thank You again for sharing a masterful design and build!!
    PJ
    Mark Twain
  6. #14
    Jan 2016
    Dubrovnik, Croatia
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    PJ
    gear setting accordion as you call it is just printout of the drawing in actual size 1:1 ratio and I actually used original gears to check if everything is fine. Gears were created by program GearDXF. Then opened by LibreCAD and rotated if required. (both freeware programs) Then copied to and completed in Paint and saved as 16 colour Bitmap image.
  7. #15
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PJs's Tools
    In the video between :55 and 1:00 is that a piece of paper to set the gear engagement or metal. Didn't use the right words sorry...maybe setting the lash?? I use paper on my Mini Lathe when changing gears or move the banjo.
    Mark Twain
  8. #16
    Jan 2016
    Dubrovnik, Croatia
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Yes. That's piece of paper. The same thickness which I use when changing gears at banjo.
  9. The Following User Says Thank You to LMMasterMariner For This Useful Post:
    PJs (08-28-2018)
  10. #17
    Apr 2016
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    awesome. now If I can just put synchronizers on it and put it in my car..... what a work out that would be shifting... keep up the great work!!!
    Post your reply!
    eBooks for Supporters
