Results 1 to 10 of 18
Thread: 28" wood / coal forge build
  1. #8
    quite a bit of progress today all things considered
    First off I had to make a retaining ring for the iris blade control disk
    the retaining ring is 1/8 by 3/4" flat bar bent the hardway. I used my bender roller to accomplish this
    Bender roller combo
    setting up for offset drilling of the iris blade stem support sleeve
    the retaining ring the stem supports and the control linkages are now in place
    I just have to weld on some bolts to the control disk then make a flange and "T" for the air supply and the cleanout of the toyere then the underside will be pretty much done
  2. The Following 9 Users Say Thank You to Frank S For This Useful Post:
    baja (May 26, 2020), clydeman (May 25, 2020), Drew1966 (May 31, 2020), Jon (May 25, 2020), Lee Bell (May 25, 2020), Scotsman Hosie (May 26, 2020), suther51 (May 25, 2020), thevillageinn (May 25, 2020), toeless joe (May 25, 2020)
