Results 1 to 4 of 4
Thread: 3 in 1 multi tool!
    Haslip Cycle Works's Avatar
    Haslip Cycle Works's Tools
    3 in 1 multi tool!
  2. The Following 3 Users Say Thank You to Haslip Cycle Works For This Useful Post:
    Gregraper33712 (10-27-2020), Jon (10-27-2020), rgsparber (10-26-2020)
    Thanks Haslip Cycle Works! We've added your Multi-tool to our Fastening category,
    as well as to your builder page: Haslip Cycle Works's Homemade Tools. Your receipt:
    Sep 2020
    Actually useful in some situations
    <div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-multi-tool"> <img src="/uploads/236632/homemade-multi-tool.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-multi-tool">Multi-tool</a> <span> by <a href="https://www.homemadetools.net/builder/Haslip+Cycle+Works">Haslip Cycle Works</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/hand-tools'>hand tools</a> </div> </div> </div> </div>
    In the video, the poster referred to the contraption as "an interesting conversation piece" but not very useful. There was a time long ago when I was "on the road" on a motorcycle. Crossed the country a couple of times, sleeping under bridges etc, typical of the times. I carried enough tooling to literally rebuild the machine on the spot. Such a tool would have been useful to me for the reduction of weight and physical size. I carried each of the tools individually although they took a lot of space. I also carried my "electrician's pouch" because a good electrician can find work almost anywhere. It would have been "handy" for that as well. Not very useful in a shop, but worth it's weight for portable use.
    Bill Hudson
    It's not uncommon to see a hammer head of some sort attached to a wrench that fits the drawbar hex on a mill. Such a "hench"* is used to first loosen the drawbar and then hammer it gently to free the taper of whatever was held in the spindle by the drawbar.
    While what was shown resembles a hench, there would be no need of the adjustable wrench - the drawbar hex doesn't change its dimensions.
    Rather than attach a ratchet to an adjustable wrench, a much more useful idea is a homemade version of this Harbor Freight wrench...
    https://www.harborfreight.com/14-in-...het-67993.html
    which has a 1/4 ratchet at one end and a 3/8 at the other. I find it to be a very handy tool indeed. With 1/4 to 3/8 and 3/8 to 1/4 adapters this wrench can be set up to hold two 1/4 sockets or two 3/8 or one of each.
    * My version of a hench is shown here...
    The HENCH
    Post your reply!
    eBooks for Supporters
    Home Shop Freeware
