Results 1 to 10 of 10
Thread: 30°-45°-60° V-Block
    Dec 2013
    Florida
    rossbotics's Tools
    30°-45°-60° V-Block
    I was making some new locking handles for the table and cross feed on my mill the other day and had a brain storm, these handles I’m making have a locking lever that requires a tapped hole at 30° to the axis of the handles screw, drilling and tapping these holes at that angle is not a problem if you had just the right size v-block with an angle plate under it, they could also be tapped with just an angle plate under them or a dividing head and several other ways, the jaws on the mill vise are only 1-3/8” tall so it was a toss up to make just the right size v-block with an angle plate under it or just make a v-block with some common angles machined into it, so I decided to go with a v-block with three different angles milled into both faces, one side of the v-block has a 30° angle milled into it and the other side has a 45° and a 60°, the v-block is ground to the same height as the jaws on my vise making it easy to setup, the degree marks are clearly stamped to their corresponding angles, I had thought about making one of these some time ago but never got around to it nor had I the need for it until now, just another little quick setup fixture.
    This block is made from O-1 steel hardened and precision ground flat, square and parallel on all six sides, the vees were then precision ground true to the adjacent sides.
    I have included some photos of the machining and grinding processes and some photos of the block being used.
    As always thanks for looking and happy machining
    Doug
    30°-45°-60° V-Block-1.jpg 30°-45°-60° V-Block-2.jpg 30°-45°-60° V-Block-3.jpg
    30°-45°-60° V-Block-4.jpg 30°-45°-60° V-Block-5.jpg 30°-45°-60° V-Block-6.jpg
    30°-45°-60° V-Block-7.jpg 30°-45°-60° V-Block-8.jpg 30°-45°-60° V-Block-9.jpg
    30°-45°-60° V-Block-10.jpg 30°-45°-60° V-Block-11.jpg 30°-45°-60° V-Block-12.jpg
    Comments are always welcome
    Doug
  2. The Following 24 Users Say Thank You to rossbotics For This Useful Post:
    asterix (Jul 15, 2025), bigtrev8xl (Nov 22, 2018), Canobi (Jul 31, 2018), DIYer (Aug 4, 2018), emu roo (Mar 2, 2026), high-side (Apr 5, 2019), Home-PC (Mar 19, 2021), homey_g (Mar 18, 2021), HUMARIA (Feb 19, 2019), Jeff Michel (Aug 1, 2018), Jon (Aug 3, 2018), LMMasterMariner (Aug 1, 2018), mklotz (Jul 31, 2018), Moby Duck (Jul 16, 2025), nova_robotics (Mar 16, 2021), PJs (Aug 1, 2018), primy (Feb 20, 2019), saaq22 (May 31, 2022), Seedtick (Jul 31, 2018), tedayer- (Jul 15, 2025), threesixesinarow (Jul 31, 2018), tooly (May 29, 2022), TSiArt (Aug 1, 2018), uv8452 (Jul 15, 2025)
    Supporting Member gatz's Avatar
    gatz's Tools
    nice workmanship, Doug
  4. The Following 2 Users Say Thank You to gatz For This Useful Post:
    emu roo (Mar 2, 2026), tooly (May 29, 2022)
    Oct 2012
    Doug
    Very nice with the mark of excellence. Always top shelf.
    Thanks for the shot of the head cranked over for the V groove.
    Nelson
  6. The Following User Says Thank You to ncollar For This Useful Post:
    Supporting Member aphilipmarcou's Avatar
    Dec 2016
    new zealand
    aphilipmarcou's Tools
    I very much appreciate this excellent work and the methods shown so clearly.
  8. The Following User Says Thank You to aphilipmarcou For This Useful Post:
    Dec 2013
    Florida
    rossbotics's Tools
    Quote Originally Posted by gatz View Post
    Thank You gatz
    Doug
    Doug
  10. The Following User Says Thank You to rossbotics For This Useful Post:
  11. #6
    Dec 2013
    Florida
    rossbotics's Tools
    Quote Originally Posted by ncollar View Post
    Doug
    Nelson
    Thanks Nelson
    Doug
    Doug
  12. The Following User Says Thank You to rossbotics For This Useful Post:
  13. #7
    Thanks rossbotics! We've added your V Block to our Measuring and Marking category,
    as well as to your builder page: rossbotics's Homemade Tools. Your receipt:
  14. The Following User Says Thank You to DIYer For This Useful Post:
  15. #8
    Jan 2017
    NOLA
    Doug, that is a well-made, useful, and beautiful part. I love it.
    This is not a criticism, but a curiosity. I have a nagging concern over your surface grinder placement. Maybe you have defining reasoning that I can't know for placing your grinder like it is, but I saw that and it made me hesitate. It's common practice to turn the surface grinder so there's a backstop behind the wheel. That's so any broken wheels or thrown parts don't fly across the room and hit someone or something, but into a solid stop, like a wall. I've been using surface grinders for 20 years (before my wreck), ending my career working from a Jung CNC profile grinder making one-off and short run parts (it's most commonly used for jet engine turbine blades). I've knocked away parts and broken wheels a few times, and there's a lot power behind the projectiles. Your thin metal wall could be reinforced with an alternate material directly behind the grinder.
  16. #9
    Oct 2012
    Doug
    Very nice and showing the set-ups to cut the "V"s.
    Very nice.
    Nelson
  17. #10
    hemmjo's Tools
    That is very nice. I do enjoy making things. Perhaps the most fun part, is making the tooling needed to allow fabrication of whatever it is that you needed in the first place.
    Makes me wish I had a mill and surface grinder, etc. But, have to make do with what you have.. or can make.
    Download plans for milling tools.
