Hello my New DIY video ..
4 WAYS HOW TO REUSE OLD REFRIGERATOR MOTOR COMPRESSOR
https://www.youtube.com/watch?v=lv6nj_CL3f8&t=129s
Thanks Mr.DK DIY! We've added your Air Pump to our Miscellaneous category,
as well as to your builder page: Mr.DK DIY's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-air-pump-4"> <img src="/uploads/228268/homemade-air-pump-4.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-air-pump-4">Air Pump</a> <span> by <a href="https://www.homemadetools.net/builder/Mr.DK+DIY">Mr.DK DIY</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/air'>air</a>, <a href='https://www.homemadetools.net/tag/pump'>pump</a> </div> </div> </div> </div>
Thanks Mr.DK DIY! We've added your Water Pump to our Miscellaneous category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-water-pump-7"> <img src="/uploads/228283/homemade-water-pump-7.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-water-pump-7">Water Pump</a> <span> by <a href="https://www.homemadetools.net/builder/Mr.DK+DIY">Mr.DK DIY</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/pump'>pump</a>, <a href='https://www.homemadetools.net/tag/compressor'>compressor</a> </div> </div> </div> </div>
A note on using plastic hose on the output of air compressors, the outflowing air may get hot enough to weaken the house.
Also, while you didn't do it, some people use soldered fittings. I was walking past an air compressor at a company that some ID0T soldered the output pipe on...the solder failed from vibration as I was passing it and a 2" diameter pipe blew off. That is NOT nice when you're having a peaceful walk.
