https://youtu.be/GbGProFulHQ
If you're interested, here's a link to the butcher block ↓
https://youtu.be/-ohMt-cCopc
Thanks Make Things! We've added your Drill Bit Storage to our Storage and Organization category,
as well as to your builder page: Make Things's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-drill-bit-storage-2"> <img src="/uploads/256971/homemade-drill-bit-storage-2.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-drill-bit-storage-2">Drill Bit Storage</a> <span> by <a href="https://www.homemadetools.net/builder/Make+Things">Make Things</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/drill-bit'>drill bit</a>, <a href='https://www.homemadetools.net/tag/storage'>storage</a> </div> </div> </div> </div>
With cutting end of Forstner bit facing out? Ouch.
Understand short cylindrical section not suited to the other way. How about somewhat deeper counter bore and the backside short enough the chucking end sticks out? You'd eject chosen bit with a finger tip.
But I like idea of a shadow box/seiton index near area of use covering fractional bits. I store tap drill sizes with the corresponding cutter.
Haven't solved counterbore pilots or back spot-facers yet.
