Results 1 to 6 of 6
Thread: 9X20 Lathe Spur Gear replacement.
  1. #2
    Berkshire UK
    thehomeengineer's Tools
    Hi Captainleeward
    Thank you for all the ideas you post.
    I am unaware and have no knowledge of the lathe you have. But just a word of warning plastic gears or Tufnell gears are used in gear trains as a safety point for the machine. (Please forgive if I am incorrect in this case of your machine) The reason for having a plastic or Tufnell gear is like a fuse in a plug. It protects the machine in case of a jam up/overload. The plastic gear is the weak point in the system and the teeth can shear and protect the more expensive items like the gear box/headstock. I hope you are not offended by this observation
    Thank you again for all the ideas you post
    The Home Engineer
  2. The Following 2 Users Say Thank You to thehomeengineer For This Useful Post:
    Paul Jones (Jan 18, 2018), PJs (Jan 19, 2018)
