Results 1 to 7 of 7
Thread: Adjustable Clamping Spacers
    Supporting Member kess's Avatar
    Dec 2015
    Thessaloniki Greece
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    kess's Tools
    Materials:
    2 Bolts Low profile Allen socket head M16x35mm and 4 nuts M16.
    Tools:
    Vice, welding machine, angle grinder, file.
    Place/adjust two pairs of nuts at the vice so as the bolts can screw/unscrew correct and freely.
    Tack welds the sides of nuts using the combination:
    single sides 1-3-5 at first and then the even sides 2-4-6.
    Adjustable Clamping Spacers-first-frame_last1.jpg Adjustable Clamping Spacers-img_20200611_135812.jpg
    Adjustable Clamping Spacers-img_20200611_135039.jpg Adjustable Clamping Spacers-img_20200607_165642-epx2.jpg
    Adjustable Clamping Spacers-img_20200607_140930-epx2.jpg Adjustable Clamping Spacers-img_20200607_122545.jpg
    Adjustable Clamping Spacers-img_20200607_123805.jpg Adjustable Clamping Spacers-img_20200607_133427.jpg
    Adjustable Clamping Spacers-img_20200607_140534.jpg Adjustable Clamping Spacers-untitled-1.jpg
  2. The Following 3 Users Say Thank You to kess For This Useful Post:
    Jon (07-09-2020), mwmkravchenko (07-16-2020), Toolmaker51 (07-08-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks kess! We've added your Adjustable Clamp Spacers to our Clamps category,
    as well as to your builder page: kess's Homemade Tools. Your receipt:
    Dry Gulch, Tx
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Crusty's Tools
    I use this same method for making machinist jacks, though I just use coupling nuts for the bases. I keep a variety of different bolt lengths on hand to make my supports work in the distance range that I need and sometimes I weld a thick SAE washer onto the nut for a wider base.
    Dec 2015
    Thessaloniki Greece
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    kess's Tools
    Ηι Crusty,
    Yes the washer makes the nut more stable.
    Thanks for sharing.
    Dry Gulch, Tx
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Crusty's Tools
    It does make it more stable but I've found that if a reasonably large diameter bolt is used then there's no need for the base because the coupling nut is stable enough by itself.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Coupling nuts are handy bits of hardware. For some unknown reason they are chamfered more than corresponding size hex nut. So Just like Crusty describes, but inverted, I've used bolt head as the foot. Just sand or file the grade stamping off, so it doesn't 'walk' while adjusting.
  8. #7
    Dec 2015
    Thessaloniki Greece
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    kess's Tools
    Hi Toolmaker51,
    I have rectified the head of the screw as well as the seat of the base on the lower nut.
    I also marked each pair of welded nuts with numbers (so I know which side is the right seat).
    Post your reply!
    eBooks for Supporters
  9. The Following User Says Thank You to kess For This Useful Post:
    Toolmaker51 (07-10-2020)
