Results 1 to 4 of 4
Thread: Adjustable stand, heavy
    Nov 2015
    Italy
    rendoman's Tools
    Hi! Just finished the new horn stand!
    As usual, execpt the screws, all the parts are home made.
    20mm rectified and tempered bars, brass bushings, stainless M10 threaded rod for accurate adjustments. Most of parts are 6061 alloy.
    I used engine turning on front panels, and other parts, in order to give a more refined look.
    Brass solid feet polished. It's possible to set the time alignement, rotation of turret and tilt.
    This stand is intended for horn use in hi-fi home system. Due to its heavy duty construction, this stand could be useful for pointing system or other heavy objects that need the possibility of fine adjustment.
    Adjustable stand, heavy-dsc06711_1600x1200.jpg Adjustable stand, heavy-dsc06709_1600x1200.jpg
    Adjustable stand, heavy-89819395_10221613944080632_233493990081560576_o.jpg Adjustable stand, heavy-89404947_10221606780061536_1234586029952860160_o.jpg
    Adjustable stand, heavy-89914072_10221613946760699_3970616644320886784_o.jpg
  2. The Following 9 Users Say Thank You to rendoman For This Useful Post:
    baja (Mar 10, 2022), bruce.desertrat (Mar 31, 2020), DIYer (Mar 29, 2020), HobieDave (Mar 28, 2020), Jon (Mar 31, 2020), Paul Jones (Apr 2, 2020), Ralphxyz (Feb 10, 2024), Rikk (Apr 1, 2020), Scotsman Hosie (Mar 31, 2020)
    Thanks rendoman! We've added your Horn Stand to our Dollies and Stands category,
    as well as to your builder page: rendoman's Homemade Tools. Your receipt:
    bruce.desertrat's Tools
    That is a gloriously designed and built piece of kit. Bravo!
  5. The Following User Says Thank You to bruce.desertrat For This Useful Post:
    rendoman (Mar 31, 2020)
    Nov 2015
    Italy
    rendoman's Tools
    Thank you very much!
