Thread: Air compressor build in progress
    I traded for this compressor and a tank a few years ago
    rather than disassemble the compressor pack I just decided to weld it to the top plate on the tank.
    so last week I finally got around to ordering the necessary parts to complete it.
    things like the check valve the pressure switch and relief valve the gage and a few other things so maybe this week I can get it going
  2. The Following 9 Users Say Thank You to Frank S For This Useful Post:
    Altair (Dec 2, 2019), baja (Nov 5, 2019), emu roo (Dec 19, 2021), high-side (Nov 5, 2019), mr mikey (Aug 28, 2025), mwmkravchenko (Apr 3, 2022), rlm98253 (Nov 17, 2020), Seedtick (Nov 4, 2019), thevillageinn (Nov 17, 2020)
    well at long last I finally got around to finishing up my air compressor build the final piece required re bending a work hardened 3/4" copper line
    the compressor is under powered with the motor that is on the unit but it was already mounted with the compressor head when I got it
    I haven't installed piping in my shop yet so no need to run the compressor as of yet I only plugged it in long enough to make sure it will pump air but not long enough to allow it to fully build up a tank full of pressure as the oil in the compressor needs changing
    EclecticNeophyte (Aug 28, 2025), emu roo (Aug 28, 2025)
    Thanks Frank S! We've added your Air Compressor to our Air Compressors category,
