Results 1 to 10 of 15
Thread: Almost Finished with 2" x 72" Belt Grinder Build
    Supporting Member tmate3's Avatar
    Jan 2021
    tmate3's Tools
    This was a kit supplied by Brian House that included the plans, a few metal brackets, and some hardware. I furnished the square tubing and did the necessary machine work and welding. I used a 2 HP Baldor 3 phase motor and a KBAC VFD.
    I would guess that I have about 20 hours in the project, spread out over a week. As soon as the wheels and belts arrive I will be in business.
    Almost Finished with 2" x 72" Belt Grinder Build-img_9549.jpg Almost Finished with 2" x 72" Belt Grinder Build-img_9555.jpg
  2. The Following 2 Users Say Thank You to tmate3 For This Useful Post:
    bobs409 (02-20-2021), mwmkravchenko (01-20-2021)
    Jan 2021
    tmate3's Tools
    Got the wheels today. Still waiting for the belts.
  4. The Following User Says Thank You to tmate3 For This Useful Post:
    Aug 2016
    NORTH CENTRAL WASHINGTON
    way awesome !
    Jan 2021
    tmate3's Tools
    All finished!
    With a 7" drive wheel top speed is just over 6,500 sfpm (surface feet per minute). I haven't tried grinding anything yet above maybe 3,000 sfpm, but with a 36 grit belt even that was scary fast at removing steel.
    Almost Finished with 2" x 72" Belt Grinder Build-img_9580.jpg Almost Finished with 2" x 72" Belt Grinder Build-img_9581.jpg Almost Finished with 2" x 72" Belt Grinder Build-img_9582.jpg
    Aug 2016
    even more awesomer!!!
    Jan 2021
    tmate3's Tools
    I wanted to add a bit of weight to the 2x72 grinder cart for stability purposes, and put an old 70 lb. plate off a press brake on the lower shelf. Then my eyes fixed on an old scarred up Walker Turner drill press table I had replaced that was leaning against the bottom of my lathe.
    As it turned out, when I placed the table upside down on the brake plate, it fit perfectly between four 7/8" dia. dowel pin holes. The webbing compartments on the bottom are perfect for keeping wrenches, spacers, and other grinder related items handy. I now have 100 lbs. of ballast which makes the whole works feel a lot more solid.
    No, that isn't a square hole in the middle of the drill press table. I put a small square of plywood in there so it would be flat.
  9. #7
    Aug 2016
    wizard69's Tools
    Great post!
    Another form of ballast, maybe not as useful as that table are old electric motors. I have several that are good for nothing but dead weight. In my case I often use them when gluing things up. The tendency people have with junk electric motors is to throw them out but the are so useful for dead weight that I've collected a whole bunch.
  10. The Following User Says Thank You to wizard69 For This Useful Post:
    tmate3 (01-28-2021)
  11. #8
    Thanks tmate3! We've added your Belt Grinder to our Belt Sanders and Grinders category,
    as well as to your builder page: tmate3's Homemade Tools. Your receipt:
  12. #9
    Jan 2021
    tmate3's Tools
    Plywood Shroud for 2x72 Grinder
    I threw together a plywood cover for the grinder, which I hope will partially contain the debris and soften the noise a bit. It lifts off in seconds for belt changes, etc.
    Motor is a TEFC unit so I don't think it will be affected as long as there is plenty of air circulation around it. Cover should also provide some protection in case a belt disintegrates.
    Almost Finished with 2" x 72" Belt Grinder Build-img_9584.jpg Almost Finished with 2" x 72" Belt Grinder Build-img_8925.jpg Almost Finished with 2" x 72" Belt Grinder Build-img_8933.jpg
  13. The Following User Says Thank You to tmate3 For This Useful Post:
  14. #10
    Thanks tmate3! We've added your Belt Grinder Shroud to our Belt Sanders and Grinders category,
