Hello,today my New Homemade tool ..
Worm Gearbox 20:1 ??? DO NOT THROW THE OLD WORM GEARBOX REDUSER IN THE TRASH !!!
Amazing Homemade Log Splitter Wood Processing Machine
https://www.youtube.com/watch?v=HssQPJxtatc
That thing scares me and I'm fearless. Also, it should have a foot switch...
Thanks Mr.DK DIY! We've added your Log Splitter to our Logging category,
as well as to your builder page: Mr.DK DIY's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-log-splitter-32"> <img src="/uploads/248222/homemade-log-splitter-32.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-log-splitter-32">Log Splitter</a> <span> by <a href="https://www.homemadetools.net/builder/Mr.DK+DIY">Mr.DK DIY</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/log-splitter'>log splitter</a> </div> </div> </div> </div>
Where O where does one find old worm drive reduction gearbox's in the trash?
One does not find those in the trash. That is why I used a snowblower front gearbox on my last project...
Was this Mk.I?
https://www.youtube.com/watch?v=2bVAAx3mMKY
That's cute if you're splitting little pieces of wood. The rounds I split are 2 to 4 feet in diameter...
Percussion log splitters are very clearly dangerous, A portable saw is far safer:
https://www.youtube.com/watch?v=2c486ERD7-0
Next Darwin candidate, or is it participant?
Agreed. Horrendous. Starting with goofy turned down hat brim. What blade?
Without enough inertia for a sure cut, throws your timing off.
Hello emergency room, goodbye digits. The terrain says one not around the corner either.
I see his key-way cutting skills did not stand the test of time! His solution rather appalled me, welding the shaft at both ends to the gear hub! :-(
Severe thumbs down for that! His one bolt fastening of the electric motor, was right up there with Heath Robinson, too!
His lack of materials lead to a couple of design anomalies... see the bottom of the gearbox mounts...
The guy that designed that big splitting wheels name was "Lefty".
A kindling splitter possibly, but log splitter is perhaps a rather ambitious description. And is scares me too.
When it happens, man up and tell us; don't leave us in suspence
I found one. It was in a dentist chair that someone dropped off at the township recycling bins. Which are for can, glass bottles, card board and plastic bottles.
I got a lot good stuff out of that chair. I am still using parts of it. The wrom drive is still on my shelf. I see it in my imagination as the basis for an indexing table. But not time for that yet.
