Results 1 to 10 of 10
Thread: Angle Finder
    Dec 2013
    Florida
    rossbotics's Tools
    Angle Finder
    While toying around the other day with some angle plates and a protractor thinking of another tool to make, it dawned on me that no one has ever made one of these on Home Made Tools before, or at least to my knowledge, this tool is by no means a new idea, you can get these things from any HardwareStore, Home Depot, Lowes, Harbor Freight, Etc. for a few bucks, the only thing is their all made from plastic, I despise plastic tools.
    I made this Angle Finder especially for quick setups in the milling machine vise; I have all sorts of 4” long angle plates but sometimes you need to create an angle you don’t have an angle plate for, most of the time the angles you’re creating on the end of a work piece is not that critical anyway so this devise will work fine, when I do need that kind of precision I’ll accommodate that issue with a surface plate, sine bar and gage blocks.
    I made this tool with a 3/8” wide edge so it can sit on the part being held in the vise and not be too cumbersome, some of those plastic models I seen out there have about a 3/4”-1” wide base, way to wide for resting on something in a milling machine vise.
    The base was made from 4140 steel not hardened but ground; the protractor head was made from 6061 aluminum, the indicator from 360 brass, the scale was created in AutoCAD and printed on decal paper with four coats of clear enamel.
    I have included a few photos of the machining process along with the tool being used.
    As always thanks for looking and happy machining
    Doug
    Comments are always welcome
    Doug
  2. The Following 17 Users Say Thank You to rossbotics For This Useful Post:
    Alan Purdy (May 7, 2019), albertq (Feb 12, 2024), aphilipmarcou (Jun 25, 2018), DIYer (Jun 28, 2018), emu roo (Jul 3, 2024), johncg (Mar 13, 2023), Jon (Jun 25, 2018), LMMasterMariner (Jun 27, 2018), mklotz (Jun 25, 2018), NortonDommi (Jun 25, 2018), nova_robotics (Aug 5, 2020), PJs (Jun 25, 2018), rlm98253 (Jun 25, 2018), Seedtick (Jun 25, 2018), Stevohdee (Jun 30, 2018), Tonyg (Aug 6, 2020), Toolmaker51 (Jun 25, 2018)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    I use one of those digital with magnetic base inclinometers but yours has class!
  4. The Following 2 Users Say Thank You to NortonDommi For This Useful Post:
    emu roo (Nov 13, 2025), PJs (Jun 26, 2018)
    Oct 2016
    fandres's Tools
    Nice job Doug this is a useful tool to have and another thing that will keep me busy.
  6. The Following User Says Thank You to fandres For This Useful Post:
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    Nice work. First class!
  8. The Following User Says Thank You to Radioman For This Useful Post:
    Most of the commercial ones, of which I have two, have a full 360 degree protractor scale. This allows one to measure angles overhead. (Imagine measuring the pitch angle of a roof from inside the attic.)
    Since Doug's has only a 180 degree protractor one might expect that it can't make such measurements, but they would be wrong. The trick is to put a right angle plate against the "roof" and measure the angle relative to vertical of the part that extends outward from the "roof". This angle is the complement of the pitch angle so simple arithmetic will yield the desired measurement.
    It should be obvious that this trick is used to measure any angle that is greater than ninety degrees.
    In reality, Doug's 180 degree setup is a feature, making the tool more compact and thus easier to store.
  10. The Following 4 Users Say Thank You to mklotz For This Useful Post:
    emu roo (Nov 13, 2025), Jon (Jun 26, 2018), LucasC (Jul 13, 2018), PJs (Jun 26, 2018)
  11. #6
    Dec 2013
    Florida
    rossbotics's Tools
    Thanks NortonDommi
    Doug
  12. #7
    Dec 2013
    Florida
    rossbotics's Tools
    Quote Originally Posted by fandres View Post
    Thank You
    Yea it's just a quick setup thing, nothing high end, sometimes you need to put a quick angle on the end of something, that's what it's made for
    Doug
  13. #8
    Dec 2013
    Florida
    rossbotics's Tools
    Quote Originally Posted by Radioman View Post
    Thank You
    It came out pretty good, will work fine for it's intensions
    Doug
  14. #9
    Dec 2013
    Florida
    rossbotics's Tools
    Your right Marv
    I have one of those as well, it works fine for any angle anywhere , the base on my plastic one is so wide it's absolutely useless on the mill vise, the unit I made is only 3/8" wide and only needs to have 180° movement, 90° for either side of the vise
    Doug
  15. The Following User Says Thank You to rossbotics For This Useful Post:
  16. #10
    Thanks rossbotics! We've added your Angle Finder to our Measuring and Marking category,
    as well as to your builder page: rossbotics's Homemade Tools. Your receipt:
