Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: The angle grinder bracket
    Supporting Member Workshopshed's Avatar
    Mar 2013
    Ayrshire, UK
    Workshopshed's Tools
    That should give more support for the work, good job.
    Andy from Workshopshed
    "Making and repairing things in a shed at the bottom of the garden"
    workshopshed.com
  2. #12
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    This thread has been moved to the Must Read subforum. Congrats (and thanks) to The Fe Factor for making such a valuable contribution!
  3. #13
    Thanks The Fe Factor! We've added your Grinder Mounting Bracket to our Grinding category, as well as to your builder page: The Fe Factor's Homemade Tools. Your receipt:
  4. #14
    Jan 2016
    Moby Duck's Tools
    The whole tool is excellent and the narrow slot idea is a really good safety feature. If I was to make one I would consider extending the work rest an equal distance to the left hand side so that longer pieces can be laid across the rest.
    It would mean chopping off the top of the left side vertical box section to extend the tool rest, but when done would allow you to cut say a 1 metre or more length of steel in half.
    Another quick thought would be to make the tool rest table of angle iron with the narrow slot cut in the flat and vertical section of the angle so that the cut off blade is almost totally enclosed when viewed from the front. If the grinder guard was then adjusted down to touch the vertical section there would be less chance of a disintegrating wheel doing any damage.
    edit: The vertical of the angle rest would also serve as a backstop to keep the cuts square.
  5. The Following User Says Thank You to Moby Duck For This Useful Post:
    The Fe Factor (Mar 15, 2016)
  6. #15
    Supporting Member jotasierra's Avatar
    Sep 2015
    país Argentina, provincia de San Juan
    jotasierra's Tools
    Hola Factor..bueno el accesorio, y como mencioné en otro post, sería bueno (por lo menos para mi) un pedal de arranque-parada con un swich con sistema de seguro por arranque imprevistos, muy bueno, hasta pronto.
  7. #16
    Supporting Member Slim-123's Avatar
    Mar 2019
    Россия Краснода&
    Кронштейн для болгарки отличная идея. Что я бы добавил, так это регулятор скорости. На многих моделях он отсутствует, а щётка на скорости 8-11 тысяч оборотов очень травмоопасная штука.
  8. #17
    thirdbike's Avatar
    Mar 2015
    Modification to your braket
    As you were looking for further input and, if I may make a small suggestion, and this is just from watching the video as I haven't built a bracket yet:
    I noticed that the original grinder bracket projects above the new addition of the base plate which, by the way, is an excellent improvement.
    I'm wondering if the design may be adapted so that a longer piece of material could be cut wherein the length of material to be cut could extend past the main upright bracket support. In other words there would be a flat plane extending in both directions at 90 degrees to the cut off wheel. This may entail rerouting the support arm that connects to the back of the grinder.
    Thank you
