Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Angle grinder power file attachment
    Jyväskylä Finland
    Tuomas's Tools
    Hi this is my version of angle grinder power file.
    Preview for the final product:
    Video shows the making:
    Here's some pictures from the slots that locks it on position:
    Can be locked to two different angles.
    Wheel is from the skateboard, same that i use with my pipe sander.
    Belt is 30mm x 633mm
    Bearings are mounted to arm with two M5 rivet nuts. Nice and clean mounting, and allows to change bearings easily if necessary.
    ( i have seen people locking them with welds )
    Here's a preview to the whole mobile sander consept:
  2. The Following 9 Users Say Thank You to Tuomas For This Useful Post:
    high-side (Sep 9, 2020), Jon (Aug 8, 2018), Paul Jones (Aug 8, 2018), PJs (Aug 7, 2018), rossbotics (Aug 9, 2018), Seedtick (Aug 6, 2018), sossol (Aug 6, 2018), Trojan Horse (Feb 14, 2019), Tule (Aug 8, 2018)
    Great job Tuomas. I see you are making good use out of your homemade press break attachment for your shop press.
    Jyväskylä Finland
    Tuomas's Tools
    Thanks Frank. Bending tools really makes metal working much easier and faster.
    No need to weld so much. No need to worry about disortion.
    Making stuff with diy tools really makes whole process more enjoyable.
  5. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Aug 7, 2018)
    Supporting Member MountainMan's Avatar
    Jul 2018
    Conway,SC
    MountainMan's Tools
    Man that is awesome!!!! I could use that on a daily basis. Thanks for sharing Tuomas!
    Dave
    "I have not failed...I've just found 10,000 ways that wont work"
    Thomas Edison
  7. The Following User Says Thank You to MountainMan For This Useful Post:
    PJs (Aug 7, 2018)
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by MountainMan View Post
    Thank you for checking it out.
    Thanks Tuomas! We've added your Angle Grinder Sander Attachment to our Grinding category,
  10. #7
    Jyväskylä Finland
    Tuomas's Tools
    Continued..
    Old latch. It was spring loaded, couldn't be opened manually.
    New latch.. also spring loaded, but..
    Now it can be opened by pressing with finger. This allows to making grooves that locks the sander on its position, deeper.
    That gives stronger hold.
    Still, new latch doesn't be on the way when using grinder for cutting or sanding with discs.
    Old latch didn't allow to move guard counter clockwise, now it can be moved to both directions.
  11. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Aug 7, 2018)
  12. #8
    Aug 2016
    wizard69's Tools
    Nice work!!
    Great use of that press! When i find the time im working on a very similar press. Largely for the same reasons you highlight which is that it is better than welding for fabtications.
    As for the grinder attachments these are great examples of ingenuity. I need to see if the idea can be adapted to the grinders i have.
    In any event keep up the great work on the videos and postings!
  13. #9
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Thanks Tuomas for the added info on the latch. Awesome build.
    PJ
    Mark Twain
  14. #10
    Jyväskylä Finland
    Tuomas's Tools
    PJ
    Thanks.
    As usual.. i noticed that issue after a while in use.
    It was somewhat tight to unlock when it was in "straight" position.
    So i decided to make it softer to use.
    Now i could easily to add more optional angles to it.
    Needs only to carve new holder groove to desired position.
    But i think those two are enough.
  15. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Aug 9, 2018)
