https://www.youtube.com/watch?v=Uh58aNsYyDQ
Thanks mr_modify1! We've added your Keyway Cutter to our Brakes and Presses category,
as well as to your builder page: mr_modify1's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-keyway-cutter-10"> <img src="/uploads/257746/homemade-keyway-cutter-10.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-keyway-cutter-10">Keyway Cutter</a> <span> by <a href="https://www.homemadetools.net/builder/mr_modify1">mr_modify1</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/keyway'>keyway</a>, <a href='https://www.homemadetools.net/tag/cutting-tool'>cutting tool</a> </div> </div> </div> </div>
To refresh your memory I guess you removed a couple of teeth on the rack so that when you rotated the handle all the way in a clockwise direction the pinion spun freely where the teeth have been removed so the handle was at the topmost position to maximize the downwards stroke of the rack. Hard to explain in a meaningful way but an extremely useful mod to make to a rack and pinion arbour press.
