Results 1 to 10 of 12
Thread: Assembly Fixture For Cannon or other Models
    jjr2001's Tools
    It all started a long time ago while reading posts from this forum. I found this Cannon that Marv Klotz made.
    Marv's is a firing model but I am just making mine for display. Model Deck Gun
    I knew I wanted to build one but at the time (probably 5 or 6 years ago) I knew it was above my pay grade.
    I figured that now was the time since I had my lathe and mill and a little knowledge (much from this forum) for this build.
    The copy I am making will recoil, breech will open and is of the interrupted thread type. Still working on parts for the base.
    First I had to find the magazine where the original plans were posted. March and April of 1945 Model Craftsman magazine.
    Found the entire year for 1945 on the bay and snapped them up.
    So I started making parts..The barrel first of course and then moving on down from there. So I have enough of it finished to do a bit
    of assembly but no easy way to hold the parts in alignment. I had several work plates in the shop so I thought one of them would make a
    good base and was just right for what I wanted to do. The
    Here are the pictures of the fixture in use. It is the best way I could think of to hold 6 parts together to test for fit and function.
    The end result of the fixture and it's capabilities are just what I was looking for. Basically two angle plates with two modified spindles at the top.
    The two pins are made from 1/2-20 all-thread. One end of each is bored to match the trunnion pins. (other end left undrilled for future use).
    Two brass knobs with fine knurls..(I can't pass up a chance to knurl!)
    10-32 allen cap screws attach the vertical post to each base and a .260 slot in the base allows for coarse adjustment.
    5/8" x 1 1/4" aluminum bar stock for bases and posts. Extra holes spotted for future use and the layout lines are left in place.
    I made it larger than needed for future modification.
    Posts are 4 7/8" long and the bases are 1 1/4" x 2" long.
    Here's the pics:
    Attached Thumbnails Attached Thumbnails Assembly Fixture For Cannon or other Models-img_2551.jpg   Assembly Fixture For Cannon or other Models-img_2552.jpg   Assembly Fixture For Cannon or other Models-img_2553.jpg   Assembly Fixture For Cannon or other Models-img_2554.jpg   Assembly Fixture For Cannon or other Models-img_2555.jpg
    Assembly Fixture For Cannon or other Models-img_2556.jpg   Assembly Fixture For Cannon or other Models-img_2558.jpg
    Back to the shop.
  2. The Following 18 Users Say Thank You to jjr2001 For This Useful Post:
    baja (May 27, 2020), bgerens (May 25, 2020), darkoford (May 26, 2020), desbromilow (May 26, 2020), emu roo (Aug 25, 2025), freddo4 (May 30, 2020), high-side (May 27, 2020), Home-PC (May 29, 2020), Jon (May 26, 2020), Metallurg33 (Sep 22, 2023), mklotz (Nov 7, 2022), old_toolmaker (May 30, 2020), Paul Jones (May 26, 2020), Seedtick (May 26, 2020), Sleykin (May 26, 2020), thehomeengineer (May 26, 2020), Tonyg (May 27, 2020), Toolmaker51 (May 30, 2020)
    Thanks jjr2001! We've added your Model Assembly Fixture to our Model Making category,
    jjr2001 (May 24, 2020)
    I'm flattered that my post inspired you. Looks like you are well on your way to making a great model.
    The setup jig is a good idea. In retrospect, I wish I had had one (or built one) when I was making my version.
    Be sure to show us more progress photos as you continue and, of course, the finished product when it's ready.
    If you run into any snags feel free to PM or email me and I'll attempt to help.
  6. The Following 4 Users Say Thank You to mklotz For This Useful Post:
    emu roo (Aug 25, 2025), jjr2001 (May 24, 2020), Paul Jones (May 26, 2020), Sleykin (May 26, 2020)
    jjr2001's Tools
    Thanks Marv, I have been inspired by many of your tool and model builds. I read this forum often for ideas and methods and frequently find one of your posts to be just what I was looking for.
    Thanks again, JR
    Back to the shop.
  8. The Following User Says Thank You to jjr2001 For This Useful Post:
    Berkshire UK
    thehomeengineer's Tools
    Looks really good. Looking forward to seeing the finished model.
  10. The Following 2 Users Say Thank You to thehomeengineer For This Useful Post:
    emu roo (Aug 25, 2025), jjr2001 (May 28, 2020)
  11. #6
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Very impressive fixture and crystal clear photos.
  12. The Following 2 Users Say Thank You to Paul Jones For This Useful Post:
  13. #7
    takkleberry's Avatar
    Aug 2017
    takkleberry's Tools
    As a former Armament Fitter I would like to say that is awesome. Well done.
  14. The Following 2 Users Say Thank You to takkleberry For This Useful Post:
  15. #8
    Congratulations jjr2001 - your Model Assembly Fixture is the Homemade Tool of the Week!
    Another big week around here, but this is a solid winner. Nice job taking inspiration from mklotz's previous post on this forum, and turning that inspiration into a homemade tool.
    Sheetmetal Bending Techniques by rgsparber
    Height Scribe by JKeetonKnives
    Bullnose Shoulder Rebate Plane by Philip Davies
    Broken Taper Removal Method by thehomeengineer
    Gear Pulley by machining 4 all
    Toolbox by Crusty
    Table by Salix84
    Height Gauge by Didpoolhall
    Lathe Carriage Lock by machining 4 all
    Sheetmetal Cutting Sled by rgsparber
    Metal Putty by Kovanca Polock
    Keyway Cutting Tool by machining 4 all
    Tap Alignment Fixture by machining 4 all
    Sanding Block by RCTURKA
    Electroplating Setup by Kovanca Polock
    Vise by Kwandotechnic
    Magnetic Ground Clamp by Mr.DK DIY
    Drill Bit Sharpening Jig by Didpoolhall
    Puller by ttmrj
    Drill Press by Kwandotechnic
    Slide Hammer Guard by tony b
    DTI Holder by MachineNZ
    Adjustable Wedge Parallel by ttmrj
    3-Axis Welding Clamp by fawabros
    CNC Hot Wire Foam Cutter by Sgbarker
    Chicken Feeder by mariost
    jjr2001 - you'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
    More importantly, this is your 5th Homemade Tool of the Week win! I've just added the silver wrench-on-pedestal graphic to the awards showcase in your postbit, visible underneath your avatar.
    Great job, and you're in excellent company joining these other 5-time winners: rgsparber, rossbotics, Christophe Mineau, Brendon, Frank S, mklotz, Vyacheslav.Nevolya, brianhw, LMMasterMariner, Tuomas, olderdan, tonyfoale, bobs409, thehomeengineer, and Stevohdee.
    Here are all of your Homemade Tool of the Week winning tools. Congrats again
  16. The Following 2 Users Say Thank You to Jon For This Useful Post:
    emu roo (Aug 25, 2025), jjr2001 (May 30, 2020)
  17. #9
    jjr2001's Tools
    Thank you Jon. I started out making tools and fixtures to make parts for airplanes. RC Model aircraft were my hobby from 2006 to about 2015 or so.
    I found making tools to make other parts or tools was most enjoyable so now I make models so I can make more tools. The whole process seems to drive itself!!!
    Well I do like model cannon and still make a few model planes (static display not flying).
    Thanks again, JR
    Back to the shop.
  18. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    emu roo (Aug 25, 2025), Jon (May 29, 2020)
  19. #10
    I've found that same journey-is-the-destination realization in our homemade tool building culture throughout the years: the tool is the project.
    People can keep building tools, only to use those tools to build more tools. They can do this without ever having to legitimize the building of the tool by using it to build a non-tool item. This is intellectually challenging, culturally satisfying, and a perfectly valid hobby. The tool building itself is and always was the true destination.
  20. The Following 3 Users Say Thank You to Jon For This Useful Post:
    emu roo (Aug 25, 2025), jjr2001 (May 30, 2020), old_toolmaker (May 30, 2020)
