Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Assembly Fixture For Cannon or other Models
    jjr2001's Tools
    Alignment Fixture Proof of Concept
    The fixture worked perfectly. I used solder paste after cleaning all parts with Acetone. The parts were assembled with a light layer of paste and I added two fiber washers to each trunion pin to reduce heat loss from the fixture. Only needed about 15 or 20 seconds on each side (from the inside of the housing) with my propane torch.
    First picture is the assembly as it was soldered.
    Picture 2 is the part from the bottom and you can see just a tiny bit of over solder. (It is on the bottom and I am leaving it!)
    Picture 3 shows the fixture ready to release the assembly. It had just enough clearance to exit the fixture without taking the fixture apart.
    The fixture will be used to install more parts when they are ready.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Assembly Fixture For Cannon or other Models-img_2560a.jpg   Assembly Fixture For Cannon or other Models-img_2563a.jpg   Assembly Fixture For Cannon or other Models-img_2561.jpg
    Back to the shop.
  2. #12
    jjr2001's Tools
    Final Picture
    Here is the assembled picture.
    All the parts are in this Post:
    Deck Gun
    Attached Thumbnails Attached Thumbnails Assembly Fixture For Cannon or other Models-img_2603a.jpg   Assembly Fixture For Cannon or other Models-img_2602a.jpg
    Back to the shop.
  3. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    mklotz (Jun 6, 2020), Paul Jones (Jun 7, 2020)
