Results 1 to 9 of 9
Thread: Assortment of tiny unique tools - video
    Mentioned
    0 Post(s)
    Tagged
    5 Thread(s)
  2. The Following 5 Users Say Thank You to Jon For This Useful Post:
    high-side (07-06-2020), jimfols (07-01-2020), Philip Davies (07-05-2020), Scotty12 (07-04-2020), Toolmaker51 (07-02-2020)
    Aug 2012
    Australia
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    desbromilow's Tools
    @5:54 - pipe deburrer
    Dec 2017
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by desbromilow View Post
    I'd have said case deburring tool for primer pocket and case mouth for reloading ammo: https://www.forsterproducts.com/prod...eburring-tool/
    I have a much larger one for pipe up to 1" but even for 1/4" copper you need a larger grip area to hold it. https://www.swagelok.com/assets/imag.../MS-TDT-24.jpg
  5. The Following 2 Users Say Thank You to NeiljohnUK For This Useful Post:
    Jon (07-02-2020), Toolmaker51 (07-02-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Absolutely correct, reloaders deburring tool. On the rare occasions I've parted off small short brass tubing to length, kept one in my Kennedy box. And no one else had ever seen such a tool. Saved a lot of time versus set-up and manipulating ID/OD chamfering tools.
    Mr. Pete is one of a very small group of worthwhile YouTuber's. Common to pick up unfamiliar insights in their presentations. And they can make entertainment out of working an ice cube tray.
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Why fishermen's split shot in a machinist's toolchest ? When you don't want to mark the shaft with the setscrew, you drop one in the hole before you thread the setscrew in. Everybody knows that.
    Did he discuss the watch hand removing tool ? Here's a video describing its use...
    Home Shop Freeware
  8. The Following 2 Users Say Thank You to mklotz For This Useful Post:
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Setscrew on split shot....sounds like a gourmet menu item.
    And about the same size portion....
    Never saw that kind of hand remover. Indicators would seem to work with same amount of press fit, but watching long ago, the tech used one screw operated. More or less a tiny fine-thread C-clamp, the stationary pad was notched. He was British, and may have made it himself.
  10. #7
    Aug 2012
    Australia
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    desbromilow's Tools
    marv - thanks for that pointer on the split shot - i'm so used to using strimmer line or clippings from brazing rod I'd overlooked sinkers for that purpose.
  11. #8
    Dec 2017
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Absolutely correct, reloaders deburring tool. On the rare occasions I've parted off small short brass tubing to length, kept one in my Kennedy box. And no one else had ever seen such a tool. Saved a lot of time versus set-up and manipulating ID/OD chamfering tools..
    Indeed, though I prefer the Lee tool for case prep
    https://capandball.com/wp-content/up...3/10/90109.jpg
  12. #9
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Most split shot is too large for the miniature setscrew sizes I encounter frequently. Years ago I bought a bag of #9 bird shot from a reloading supplier; it's served many uses over the years. At 0.085" diameter it will fit in a 2-56 hole. Another use is for conformable weights when gluing odd-shaped structures...
    A bean bag for the shop
    Post your reply!
    eBooks for Supporters
    Home Shop Freeware
