Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 36
Thread: Atmospheric Water Generator.
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Atmospheric Water Generator. This is a home made AWG. Here in California we need all the water we can get.
    This is a dehumidifier that gets h2o from the moisture in the air about 5 Gallons a day. It has a 30 Gallon tank and extra black Berky filters in side.
    Atmospheric Water Generator.-038.jpgAtmospheric Water Generator.-020.jpgAtmospheric Water Generator.-033-2-.jpgAtmospheric Water Generator.-033.jpgAtmospheric Water Generator.-042.jpgAtmospheric Water Generator.-041.jpgAtmospheric Water Generator.-pc020022.jpgAtmospheric Water Generator.-pc020023.jpg
  2. The Following 19 Users Say Thank You to Captainleeward For This Useful Post:
    baja (Nov 1, 2019), emu roo (Sep 12, 2024), farhad1 (Jan 20, 2016), Jakeapart (Mar 25, 2017), kbalch (Jan 9, 2015), kutzbill (Sep 8, 2017), mwmkravchenko (Nov 25, 2025), nova_robotics (Jan 1, 2023), Paul Jones (Jan 13, 2015), PJs (Jan 23, 2016), Quinton 357 (Oct 31, 2019), rdarrylb (Jan 31, 2024), Resident114 (Jan 30, 2024), rlm98253 (Dec 10, 2021), robertblacksmith (Nov 2, 2024), Seedtick (Sep 8, 2017), thoms_here (Nov 19, 2017), Toolmaker51 (Dec 11, 2021), winmj9 (Sep 20, 2016)
    Jan 2015
    rob streeper's Tools
    That's a really good thing to have. What are the details, i.e. how does it operate and about what does one cost to put together?
  4. The Following User Says Thank You to rob streeper For This Useful Post:
    emu roo (Sep 29, 2025)
    Not bad! 5 gallons a day? After passing through those filters do you need to refilter to make the water potable?
    Jul 2014
    Hi Rob,Diyer,
    Water is pulled into the condenser via a electric fan. which gathers the water on the fins, small fridge,, then it gos to the 5 gallon bucket that is inside the 30 gallon drum. The 5 gallon bucket has two Berky filters that remove most of the contaminants. The water is then pumped thru a line to a spicket. There are many ways to filter water, it depends the area you live in to know which ones are the best to use, it is best to consult a professional to know which filtration to use for your area.
    Cost of all the parts between $400. and $5oo. This unit was made to operate outside.
  8. The Following 2 Users Say Thank You to Captainleeward For This Useful Post:
    emu roo (Sep 29, 2025), thoms_here (Nov 19, 2017)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Captainleeward! I've added your Atmospheric Water Generator to our Miscellaneous category, as well as to your builder page: Captainleeward's Homemade Tools. Your receipt:
  10. The Following User Says Thank You to kbalch For This Useful Post:
  11. #6
    You mentioned a small fridge, plus a fan. How many watts does it consume? I do know that in your case, you've got free power.
  12. The Following User Says Thank You to DIYer For This Useful Post:
  13. #7
    Jul 2014
    Hi Diyer, consumes 400 watts electricity here in California it is still cheep, but I can use my solar/wind generator system to power it up for 5 o6 six hours if I really need to. it stays on mostly at night. this is when the humidity is the highest here. :O)
  14. The Following 4 Users Say Thank You to Captainleeward For This Useful Post:
    emu roo (Sep 29, 2025), Powless Design (Jan 10, 2015), rlm98253 (Dec 10, 2021), thoms_here (Nov 19, 2017)
  15. #8
    Dec 2014
    Newtonville Ontario Canada
    Powless Design's Tools
    Very Cool!!!!!
    400 watts per hour assuming it runs for 8 hours per day means that here in Ontario, Canada it would cost about $0.60 per day. Cheap water.....
  16. The Following User Says Thank You to Powless Design For This Useful Post:
  17. #9
    Jul 2014
    Hi Power Design, of course the amount of humidity in the air varies we have usually 50 to 60 % because we are near the ocean so we get the on shore clouds and fog ect. it is necessary to have more that 30% humidity for the unit to be useful.
    60% will yeald 5 gallons of h2o per 8 hr. day.In the house the humidity is 10% higher but we like the humidity so better to have the unit out side for us. I have more pictures of the build if any body is interested. :O)
    this is a float switch turns off the unit when the tank is full
  18. The Following 2 Users Say Thank You to Captainleeward For This Useful Post:
    emu roo (Sep 29, 2025), Slim-123 (Nov 1, 2019)
  19. #10
    Very neat. Free water from free power.
  20. The Following User Says Thank You to Altair For This Useful Post:
