Results 1 to 6 of 6
Thread: Auto direction changing chain drive mechanism - GIF
    May 2024
    baja (Jul 4, 2025), emu roo (Jul 4, 2025), nova_robotics (Jul 6, 2025)
    Supporting Member carl blum's Avatar
    Nov 2021
    Charleston, South Carolina
    carl blum's Tools
    Hi Gang:
    Is there a second long link that reverses the chain down again?
    Carl.
    Supporting Member gatz's Avatar
    gatz's Tools
    Seems the slides should be centered on the sprocket. The return of the lower links is jerky even in this model.
    There is so much wrong with this model it is hard to explain. First off as Gatz mentioned the guide ways are not conducive for a smooth operation Second the only way for this to be a true reversing operation would be for there to be a second link below the upper link after a short length of chain. If you notice in the model the chain jumps from one side of the sprocket to the other the only way that can happen is to remove it and reinstall it on the opposite side. Since the sprocket has to be the driving force here with tension on both ends of the chain adding the second link is the only way I see it working
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    Just because you can model it in CAD and animate it doesn’t mean it actually works.
    I worked for a guy who used CAD like this. Things he drew often weren’t possible to build.
  8. The Following User Says Thank You to thevillageinn For This Useful Post:
    Floradawg (Jul 4, 2025)
    Quote Originally Posted by thevillageinn View Post
    You have to be smarter than the cad program otherwise you can spend countless hours and buckets full of money in prototyping
  10. The Following User Says Thank You to Frank S For This Useful Post:
