Using a one way clutch, this quill handle modification allows one hand easy setting of the handle position without set increments.
https://youtu.be/aF6PC8VylTc?si=jmkLsdaGONBB7tEc
Thanks Mook! We've added your Milling Machine Handle to our Milling category,
as well as to your builder page: Mook's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-milling-machine-handle"> <img src="/uploads/261664/homemade-milling-machine-handle.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-milling-machine-handle">Milling Machine Handle</a> <span> by <a href="https://www.homemadetools.net/builder/Mook">Mook</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/handle'>handle</a>, <a href='https://www.homemadetools.net/tag/mill'>mill</a> </div> </div> </div> </div>
Here is a McMaster reference for the type clutch he used in this design.
https://www.mcmaster.com/products/ro...ring-clutches/
For those who are curious, he explained how this works on his Q&A in the yt post as such:
Pressing the handle to the left can lightly lock the handle to allow the handle to retract the quill. A lot depends on your quill friction & spring pressure.
For my machine. I increased the spring pressure to help with retracting the quill. I also added a spring loaded ball plunger adjacent to the handle thread to give a little constant friction. I will consider making a plastic split washer to give a finer adjustment to the housing friction onto the quill axle.
