Results 1 to 6 of 6
Thread: Aux Jaws for 4" Kurt Style Milling Vise with prints
    jjr2001's Tools
    The dimensions of these jaws are for an Import Kurt Style 4" Milling Vise.
    The original jaw can only fit in one position since the mounting holes are not centered.
    I wanted to be able to use both the top and bottom of the jaws for different purposes.
    The jaw mounting screws are 6 mm on my vise so I slotted the mounting holes to fit.
    Several versions are shown.
    Original
    Soft for future milling as necessary.
    Soft with built in "parallel" function.
    Steel with 1/4" pins for odd and circular shapes.
    Each of the jaws can be used on either the top or the bottom as needed.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Aux Jaws for 4" Kurt Style Milling Vise with prints-img_3453.jpg   Aux Jaws for 4" Kurt Style Milling Vise with prints-img_3454.jpg   Aux Jaws for 4" Kurt Style Milling Vise with prints-img_3443.jpg   Aux Jaws for 4" Kurt Style Milling Vise with prints-img_3444.jpg   Aux Jaws for 4" Kurt Style Milling Vise with prints-img_3446.jpg
    Attached Files Attached Files
    Download plans for milling tools.
    Back to the shop.
  2. The Following 2 Users Say Thank You to jjr2001 For This Useful Post:
    Jon (Jan 14, 2025), mr mikey (Jan 14, 2025)
    Thanks jjr2001! We've added your Mill Vise Auxiliary Jaws to our Vises category,
    New plans added on 02/05/2025: Click here for 2,738 plans for homemade tools.
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
    Very nice, these are in my future plans.
  5. The Following User Says Thank You to mr mikey For This Useful Post:
    jjr2001 (Jan 14, 2025)
    Apr 2012
    NorCal
    Saltfever's Tools
    A suggestion is a couple of dowel holes on the inside face could locate stock for precision machining. Angle blocks or trig can accurately locate the holes. Pic is only to demonstrate. Doesn't have to be that complicated. I only use 3 angles.
    Thanks, JJ for your great post.
    Link here for video:
    I have ZERO affiliation to this company.
    jjr2001's Tools
    Thanks, Mr Mikey, show us your build after ya get er done!
    Back to the shop.
    jjr2001's Tools
    Nice fixture you have there Saltfever. Yup, the jaw faces can always be setup
    for various needs. That is another reason I like aux jaws.
    Cheers, JR
    Back to the shop.
