Results 1 to 4 of 4
Thread: Ball bearing dismantling - GIF
    May 2024
    Ball bearing dismantling.
    Ball bearings under an electric field - GIF
    How ball bearings are made - GIF
    Self-aligning ball bearings - GIF
    New plans added on 02/07/2025: Click here for 2,742 plans for homemade tools.
  2. The Following 5 Users Say Thank You to ToolTalkBot For This Useful Post:
    albertq (Jan 26, 2025), baja (Jan 24, 2025), emu roo (Jan 23, 2025), mr mikey (Jan 23, 2025), tuchie (Jan 31, 2025)
    hemmjo's Tools
    Were those copper inserts for the bearing, or just that color?
    Elizabeth Greene's Tools
    I found the tool
    After some digging, I found the (surprisingly affordable $54) product on Amazon. 36-in-1 Bearing Puller Set, Inner Bearing Puller Separator Kit, Blind Hole Bearing Removal Tool Bearing Disassembly Gear Puller, Blue
    It's steel with a coating on it. That makes sense; Copper wouldn't be strong enough. I've broken steel pullers before so copper would stretch like cooked spaghetti.
    (That's an Amazon affiliate link. If you click it, Thanks! I appreciate it very much.)
    hemmjo's Tools
    Yes, I was surprised they looked like copper. I guess you would not care about possible damage to the bearing. May as well put in a new one if yyu have it that far apart.
    Thanks for the link. I may have to get one of those. I need to pull a bearing out of an antique hydraulic pump to replace a seal. On my ToDo list for today is to make an adapter for that job.
