My latest creation :D is this fixture plate for a band saw. This allows you to cut small parts safely, even smaller than shown.
Attachment 27997
Attachment 27998
Attachment 27999
Attachment 28000
Attachment 27997
Attachment 27998
Attachment 27999
Attachment 28000
This is a real simple, but very well thought out fixture plate. I'll definitely be making something similar for my bandsaw.
Thanks,
Jack
How do you handle 45 deg angle cuts?
Nice job for 90 deg cuts and small parts, I am trying to re engineer my band saw into a mitering one like ellis saw.
I don't see anything in Bob's design that prevents the vise on the band saw from being moved to any angle of 0 to 45. Just put the other end of the square tube (leave one end square) in the vise, and cut it off to 45. Then it will be parallel to the blade cut. The threaded fixture holes and thumb wheel jack, will still hold the work piece.
I really like this fixture idea.
Thank you Bobs409!
Capital idea in use of tubing for a base, for others C-channel is good too. Accomplishing miters, at least some, are possible with Bobs409 tool.
The fixture is already in place, only need stops for locating material at positions other 90°. Extend range by widening plate between vise jaws. Builder could populate with more tapped holes as well.
Thanks ! I was looking for a solution for small parts, and I really like yours.
Easy and efficient, I'll do it.
Great idea, thanks for sharing
Doug
For angles use angle blocks, sine bars or whatever on top of the 2x3. Shouldn’t be a big deal for shallow angles steeper angles would benefit from a larger block. More mounting holes wouldn’t hurt either. All in all an excellent idea.
Thanks bobs409! We've added your Bandsaw Fixture Plate to our Workholding category,
as well as to your builder page: bobs409's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-bandsaw-fixture-plate"> <img src="/uploads/220872/homemade-bandsaw-fixture-plate.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-bandsaw-fixture-plate">Bandsaw Fixture Plate</a> <span> by <a href="http://www.homemadetools.net/builder/bobs409">bobs409</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/bandsaw'>bandsaw</a>, <a href='http://www.homemadetools.net/tag/fixture'>fixture</a> </div> </div> </div> </div>
Congratulations bobs409 - your Bandsaw Fixture Plate is the Homemade Tool of the Week!
We've certainly seen our fair share of fixture plates. To win this award with one, you have to do a really good job, and it's obvious that you have.
I should also note that, with our recent influx of talented YouTubers raining excellent homemade tools on us, we've been able to do something really important for intellectually-driven Communities of Practice (that's us) - we've upped our difficulty level. We benefit greatly from a perpetually increasing challenge, and it's good to see the same dynamic in play with both our new and old members: the cream still rises to the top. :cool:
Some more nice picks from this week:
Branding Iron and Wax Seal by Dimitris Polychronis
Lathe Tachometer by Captainleeward
Lathe Carriage Stop by jjr2001
Replaceable Face Hammer by new_guy
Tailstock Die Holder by Captainleeward
Laser Printer Toner Transfer Method by rgsparber
Belt Buckle Knife by Mikhandmaker
Metal Caliper Marker by Captainleeward
Motorizing a Leather Patcher by polyfractal
Lathe Centering Tool by rendoman
3-in-1 Portable Table Saw by Didpoolhall
Tormek Clone by Sam's Workshop Diary
CNC Bed by motopreserve
Drum Sander Rotary Tool by Foxtrot_
Hinged Bench by ranald
Bottle Jack Metal Bender Modification by Let'sLearnSomething
Mill Threading Attachment by giangthetool
Mini Mill Lighting by H0$$
Zero Clearance Table Saw Insert by ranald
Router Bit Remover by ranald
Water Heater Trash Incinerator by Savage11
Clamp Wire Binding Tool by diyfixman
Dust Extractor by ranald
Blower by Lahis
Chuck Guard by threesixesinarow
Transportable Bench by ranald
Speaker Time Alignment Tool by rendoman
2x48 Belt Sander by athomp
Fastener Bin by Downeast Thunder
Tractor Bull Bar by ranald
Gaff by Downeast Thunder
3D-Printed Metal Lathe Jaws by buddyman100
bobs409 - we've added your tool entry to our All Homemade Tool of the Week winners post.
Most importantly - this is your 3rd Homemade Tool of the Week win! You join these other 3-Time Homemade Tool of the Week winners: rgsparber, rossbotics, mr95gst, Paul Jones, Christophe Mineau, Captainleeward, immortalx, scorch, Brendon, Frank S, mklotz, Vyacheslav.Nevolya, brianhw, LMMasterMariner, jjr2001, Tuomas, olderdan, tonyfoale, Mikhandmaker, thehomeengineer, old_toolmaker, Stevohdee.
You'll notice the 3-Time Homemade Tool of the Week award trophy graphic in your postbit beneath your avatar.
https://www.homemadetools.net/forum/...OfTheWeek3.pnghttps://www.homemadetools.net/forum/...eWeekIcon3.png
You'll be receiving a $25 online gift card, in your choice of Amazon, PayPal, or bitcoin. Please PM me your current email address and gift card choice and I'll get it sent over right away.
Nice work! :thumbsup:
Here are all three of your Homemade Tool of the Week winning tools:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/tricked-out-harbor-freight-bead-roller-awesomeness-55146#post81250"> <img src="/uploads/162253/homemade-bead-roller-modification-4.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/tricked-out-harbor-freight-bead-roller-awesomeness-55146#post81250">Bead Roller Modification</a> <span> by <a href="https://www.homemadetools.net/builder/bobs409">bobs409</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/bead-roller'>bead roller</a>, <a href='https://www.homemadetools.net/tag/drill'>drill</a>, <a href='https://www.homemadetools.net/tag/modification'>modification</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/diy-square-hole-punch-press-63288#post98592"> <img src="/uploads/204353/homemade-square-hole-punch-press.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/diy-square-hole-punch-press-63288#post98592">Square Hole Punch Press</a> <span> by <a href="https://www.homemadetools.net/builder/bobs409">bobs409</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/press'>press</a>, <a href='https://www.homemadetools.net/tag/square'>square</a>, <a href='https://www.homemadetools.net/tag/punch'>punch</a> </div> </div> </div> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/forum/band-saw-fixture-plate-71448#post127570"> <img src="/uploads/220872/homemade-bandsaw-fixture-plate.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/forum/band-saw-fixture-plate-71448#post127570">Bandsaw Fixture Plate</a> <span> by <a href="https://www.homemadetools.net/builder/bobs409">bobs409</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/bandsaw'>bandsaw</a>, <a href='https://www.homemadetools.net/tag/fixture'>fixture</a> </div> </div> </div> </div>
Thank you Jon! Sending a PM now...
Is there an advantage using rectangular tube instead of just a 1/4 plate?
I have been using a 1/4 inch plate with my studs and strap clamps from the mill fixture plates.
Tube [or channel] adds benefit when studs protruding from below are not pushing the fixture out of perpendicular with blade. A bit of milling on channel legs insures a good reliable parallel, plus scrap channel is found easier than box tubing.
