10 Attachment(s)
beam lathe stand
hi guys
this a beam lathe stand i made following rob`s design (aka xynudu on youtube), he was kind to walk me thru some details that make this design work so well and i added a little tweak (really tiny tweak :))
top beam
120mm channel iron 1430mm long (5" ish by 55" ish )
65mm x 6mm angle iron 500mm long (2 1/2" x 1/4" by 20")
25mm x 5mm strap 2 pcs at 200mm long
4 ea. 10mm 8.8 grade bolts
base
square tubing 50mm x 3mm (2" x 1/8")
75mm x 6mm strap 4 pcs(3" x 1/4")
it`s 850mm high (33.5") 500mm depth (20") almost 1500mm long (3 ft)
weighs about 100kg (220 pounds)
it`s not finished yet as a bank of drawers, a sheetmetal chip tray, and covers are still in process but it`s working now making parts and $$.
i know it`s not a clausing or a monarch but a well used chinese lathe... one lives with what the universe gives... :)
i anchored to the floor via 4 concrete expansion bolts, it`s solid solid no vibrations or anything. will get stiffer once finished not that it needs to.
anybody interested feel free to ask
pete
Thanks penca! We've added your Beam Lathe Stand to our Dollies and Stands category,
as well as to your builder page: penca's Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="http://www.homemadetools.net/beam-lathe-stand">
<img src="/uploads/152196/beam-lathe-stand.jpeg"/>
</a>
</div>
</div>
<div class="title">
<a href="http://www.homemadetools.net/beam-lathe-stand">Beam Lathe Stand</a>
<span> by <a href="http://www.homemadetools.net/builder/penca">penca</a></span>
</div>
<div class="tags">tags:
<a href='http://www.homemadetools.net/tag/lathe'>lathe</a>, <a href='http://www.homemadetools.net/tag/stand'>stand</a> </div>
</div>
</div>
</div>
