Results 1 to 5 of 5
Thread: Beautiful analog chain-making machine in action - GIF
Hybrid View
    Beautiful analog chain-making machine in action.
    Making heavy duty chain - GIF
    Chain making GIFs
  2. The Following 11 Users Say Thank You to Jon For This Useful Post:
    Andyt (Feb 27, 2019), baja (Feb 27, 2019), clydeman (Feb 5, 2026), Dragonhand (Feb 26, 2019), oldpastit (Feb 27, 2019), rlm98253 (Feb 26, 2019), Scotsman Hosie (Feb 26, 2019), Scotty1 (Feb 26, 2019), Seedtick (Feb 26, 2019), that_other_guy (Mar 3, 2019), Toolmaker51 (Feb 27, 2019)
    mesmerizing
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    They don’t make them like that anymore!
    Quote Originally Posted by Radioman View Post
    actually they probably do for around $5000.00 you can buy a brand new machine for making the non welded links up to 4 mm wire as shown in the video
    https://www.alibaba.com/product-deta...d8b62e3aSfgRfu
    Link welding is another machine sold separately
    Viewers take note. The wire is drawn from a spool; the first station is a straightener. The transverse wheels are typically arranged in odd numbers, usually the minimum is 5. Most are positioned by eccentrics within wheel hubs, others use a screw to adjust a slide of the wheel mount. There is drag tension on the spool so it won't birdcage, these devices are used on many sizes and variety of wire, including electronics.
    If you were to reuse electrical wire; it could be stored easily, once run through such a straightener and re-spooled. Conveyor wheels are very inexpensive source.
