Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Beautiful Flycutting
    Dry Gulch, Tx
    Crusty's Tools
    I thought I was setting the head using a quicker method (using the tools I have available) but now I understand that I wasn't checking the spindle axis to table perpendicularity. Somewhere I have an indicator beam and arbor to mount it in the spindle - I need to find it. Thanks.
    The difference I see in opposite directions is perplexing but it being due to slop somewhere seems like the right trail to follow to me.
  2. #12
    Another part of tramming is to extend the quill; that doesn't change the angularity, just magnifies it. When you retract to mill, the error will be lessened.
    When I tram, it's over well matched 1-2-3 blocks. It's then easier to swing a larger circle and X or Y for the difference. On Bridgeport pattern mills, do the 'nod' or Y axis first, then X, and recheck Y.
    The only instrument I use; Indicol clamp, Interapid test indicator. If it needs to 'perfect', I extend the clamp/ indicator far as they will go.
  3. #13
    [email protected]
    tonyfoale's Avatar
    Could you elaborate on that, I think that I must be misreading it because extending the quill would have no effect.
  4. #14
    With the joint of a mill to nod or swivel, that creates a point of rotation. Lengthening distance [hypotenuse] from indicator point to that center, like a sine bar, angle doesn't change but the side opposite 'expands' so indicator will detect out of perpendicularity.
    I'm describing as if a right angle, but the condition is more truly scalene cone until quill is at a right angle, thereby an isosceles.
    Post your reply!
    Join 41,949 of us and get our 173 Must Read Homemade Tools eBook free.
