Results 1 to 4 of 4
Thread: Belt Sander
    Supporting Member markfitz's Avatar
    Apr 2016
    Phoenix, AZ
    markfitz's Tools
    Belt Sander
    Belt Sander:
    - Belt size - 6" x 48"
    - Belt speed - 1260 ft/min
    - Motor size - 3/4 hp
    - Motor speed - 3460 rpm
    - Roller spacing - 20" nominal
    Sanding Belt tension and tracking adjustment
    I made this belt sander from an 8" bench-top grinder from Harbor Freight. With a 20% off coupon, it only cost me $40, which is a lot less than I would have paid for just a 3/4 hp motor on its own. The first parameter that must be established is the belt speed that you want. I settled on something around 1200 to 1300 feet per minute. The motor speed of 3450 rpm dictated a reduction between the motor and the Drive Roller in order to have a practical roller diameter. I reduced the Drive Roller speed by 1.9:1 down to 1816 rpm. A roller diameter of 66 mm (2.6") gave me a belt speed of 1260 ft/min. Belt rollers were made from 9 layers of Baltic birch plywood. I crowned the rollers in the middle by .060" to help the belt tracking. I tried to keep everything simple with the sanding belt tension and tracking adjustment, as shown in the picture.
  2. The Following 13 Users Say Thank You to markfitz For This Useful Post:
    Captainleeward (Feb 25, 2018), DIYer (Feb 17, 2018), LMMasterMariner (Feb 26, 2018), Marine2171 (Jun 21, 2018), nashty1 (Feb 16, 2018), NortonDommi (Jun 21, 2018), Paul Jones (Feb 26, 2018), PJs (Feb 16, 2018), rlm98253 (Jun 21, 2018), rossbotics (Feb 25, 2018), Seedtick (Feb 16, 2018), Toolmaker51 (Feb 23, 2018), Tuomas (Feb 25, 2018)
    Thanks markfitz! We've added your Belt Sander to our Grinding category,
    as well as to your builder page: markfitz's Homemade Tools. Your receipt:
    Dec 2013
    Florida
    rossbotics's Tools
    Very Good markfitz
    anything is better than harbor freight, I'm sure it will last too
    Doug
    Comments are always welcome
    Doug
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    Very good work looks like it will last a long time. I had to adjust my belt sander today went off 90* now its back. Cap . Be a friend just ask.
    Download plans for belt sanders and grinders.
