Results 1 to 6 of 6
Thread: Bending Sheetmetal in My Brake
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    A few years ago, I built my own brake. As I’m sure you know, building a machine does not mean you know how to operate it. It was only when I watched an excellent video on this subject did the light come on. This turned out to be the jumping-off point, and I wandered into new territory. This article presents a procedure for calibrating your brake, making bends, the theory behind these bends, which is essential for design, followed by a variational analysis that is tested on the bench. I conclude by comparing my calculated results with the video.
    https://rick.sparber.org/SheetMetalBending.pdf
    Thanks,
    Rick
    Rick
  2. The Following 11 Users Say Thank You to rgsparber For This Useful Post:
    Altair (May 22, 2020), Bullet500 (May 22, 2020), Carnel (May 23, 2020), jjr2001 (May 30, 2020), Jon (May 22, 2020), lavern s (May 25, 2020), Saltfever (May 26, 2020), Seedtick (May 22, 2020), Tonyg (May 26, 2020), Unisawyer (May 23, 2020), verticalmurph (May 22, 2020)
    Thanks for the refresher course Rick
    dubbby (May 24, 2020), rgsparber (May 23, 2020)
    Sep 2018
    Groningen, NL
    Carnel's Tools
    Thanx, Rick, for this excellent explanation!
  6. The Following User Says Thank You to Carnel For This Useful Post:
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    Nice work Rick! That was a nice write-up explaining everything.
    I work for a company that bends literally tons of aluminum sheet stock every year. That k-factor is also used in 3D CAD programs, and so the manufacturing engineers work to establish and maintain that k-factor and work with the IT folks to update it in the CAD program.
    Bending thousands of parts and trying to keep a tight tolerance... I think we're around 0.005 to 0.010" tolerance for bends.
    For aluminum, that k-factor can vary with the grain structure as well, which runs lengthwise on the sheet.
    I used to design many parts in the past when I was in a design role, now I'm more distant to it in my current role, so this was a nice refresher on this.
    Folding tables are a bit more difficult to get a consistent larger radius, but a press brake can better handle the larger radius and be consistent.
    Particularly for aluminum, the hardness of the material matters quite significantly. For example, we use 5052 aluminum for sheet metal....and that designation is followed by an H-number, which indicates the hardness. Higher H number means higher hardness. This matters when you are bending it, and the radius that can be bent without cracking. If your bend cracks at the edges during the bend, it will continue to crack over its lifetime and may eventually break completely.
    Countermeasures would be to increase the bend radius or go to a softer grade of aluminum.
    We've found a good balance using 5052-H32.
    Kent
  8. The Following User Says Thank You to KustomsbyKent For This Useful Post:
    Unisawyer (May 25, 2020)
    Apr 2019
    From my aviation past, teh rule of thumb was 60% stretch vs 40% shrink.
    One test students were made to do was fabricate a small box with a proper fitting lid.
    Now that's a lot of bend calculations and precise bending.
  10. #6
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Piloon,
    Bending a box is the subject of my next article. I agree, it is challenging.
    Rick
    Rick
