Nice work Rick! That was a nice write-up explaining everything.
I work for a company that bends literally tons of aluminum sheet stock every year. That k-factor is also used in 3D CAD programs, and so the manufacturing engineers work to establish and maintain that k-factor and work with the IT folks to update it in the CAD program.
Bending thousands of parts and trying to keep a tight tolerance... I think we're around 0.005 to 0.010" tolerance for bends.
For aluminum, that k-factor can vary with the grain structure as well, which runs lengthwise on the sheet.
I used to design many parts in the past when I was in a design role, now I'm more distant to it in my current role, so this was a nice refresher on this.
Folding tables are a bit more difficult to get a consistent larger radius, but a press brake can better handle the larger radius and be consistent.
Particularly for aluminum, the hardness of the material matters quite significantly. For example, we use 5052 aluminum for sheet metal....and that designation is followed by an H-number, which indicates the hardness. Higher H number means higher hardness. This matters when you are bending it, and the radius that can be bent without cracking. If your bend cracks at the edges during the bend, it will continue to crack over its lifetime and may eventually break completely.
Countermeasures would be to increase the bend radius or go to a softer grade of aluminum.
We've found a good balance using 5052-H32.
Kent
