https://youtu.be/ZQV4LKnPqPc Hello friends. Today I will show you the best idea for DIY tool Simple homemade welding clamp. To create you need a piece of metal pipe Ф70mm with a length of 6 cm, 2 pieces of geobrazny profile (40x40mm) -6cm, metal rail (40mm) 15cm, 10mm bolt and nut, 2x12mm bolt 15cm, 4x12mm nuts, 4 washers, 2x5mm paint.
If you like my projects, you can support me by subscribing.
