I have four chisels which need new handles & I can't By replacements for them,
I am going to turn them Up But need advise on what is the best type of wood to use?![]()
I don't think what kind of wood you use matters a whole lot. Just use some kind of a hard wood. But if you plan on using hammers with your chisels then I'd band the ends. I whittled handles for some chisels recently out of some wood I picked up in my yard. I think it is maple? It all seems fine to me. I banded the one handle with a bit of copper pipe. Now it can take a good beating.
Jon (Nov 29, 2016), Paul Jones (Nov 28, 2016)
cindersfella (Dec 16, 2016)
You don't specify what type of chisel handle you're looking for as replacements! Are the chisels socket end or do the tangs go into the handle?
There are several sources of good to excellent quality replacement handles. A quick search on-line should take you to Lee-Valley, Woodcraft and several other sources. However, they can be pricey.
Since you indicated that you have the ability to turn your own, that would be the cheapest solution. You can even add ferrules if you want. Copper or brass pipe cut to size and fitted to the ends work very well. As for the type of wood, look for a very dense hardwood the does not have a straight grain. In Europe they use Horn Beam, which is a very hard and dense wood in the box wood family. Basically, any hard dense wood will suffice.
Again, you don't specify what type(s) of chisels you are trying to restore. If they are bench chisels, then you have a vast choice of woods on the Janka scale that will suffice. Here is a good resource of woods and their properties and general uses Wood Properties by Species – WoodBin.
If you are looking for handles for a striking type, like a mortising chisel or a larger slick chisel, then look to the traditional type woods.
Hope this helps.
Bill
Hi, sorry I missed you. I have gone to find myself, but if I return before I get back, please ask me to wait.
Nothing ever gets built on schedule or within budget.
cindersfella (Dec 16, 2016), Jon (Nov 29, 2016)
If the chisels are for paring & light use (almost always hand pressure only) you can use something with beautiful grain. For more robust use I have had good results with hard maple, beech, and sapele. I have seen oak on the antiques I have refurbished. Dogwood is great, as is boxwood.
If you will do any prying with the chisels, watch for straight grain end-end.
Since you said you were going to turn the handles you might keep in mind which woods turn well - maple or beech are likely easier than ring-porous woods like oak or hickory.
