Results 1 to 10 of 11
Thread: BF20 like mill Gear #209 replacement
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi,
    I have a milling head that goes above my lathe bed, it's a Chinese build from the "BF20" family.
    I put here the various names I am aware of, it could help someone thanks to the magic of Mr Google ...
    Mine is labeled WMD16V, but what I ordered from Holzmann was ED750FADQ.
    The most frequent name for this machine is BF20 and from Grizzly it is G0704.
    It looks like that :
    So I learned the hard way what is a "fuse gear".
    These machine have in the gear train that drives the spindle at least one (I wonder if t's not two ?) plastic gears that are supposed to be the one that fails in case of overload, to avoid any further damage.
    That's what happened to mine, and unfortunately, the Chinese machines are not well known for their spare parts supply service.
    But after all, machines are sold to machinists, don't they, so they are supposed to make their spare parts by themselves ?
    Unless you need the broken machine to make the broken part ...
    Here is how I have rebuilt (kind of) this piece.
    Here is the part, it's the famous Gear # 209 (lot's of people have the same issue on the internet)
    The Gear 209 is under the motor support plate :
    As you can see, for a fuse, it's quite blown ...
    So like Steve Austin :
    "We can rebuild it. We have the technology. We can make it better than it was. Better, stronger, faster." ...
    Well, we'll try at least ...
    After some research and measurement, I established the spec of the gear.
    It's a 9° helix gear, module 1.25 37 teeth.
    And I don't have any gear cutter, and don't plan to buy one, it's quite expensive.
    So, first thing first, we need the tool to rebuild the tool. And to make the tool to build the tool, we need the tool to shape the tool to build the tool....
    That will be my latest toy which is a nice little desktop CNC I have just adopted in the shop.
    So with the cnc, I will grind a kind of shape tool which will be actually a D bit from a broken 4mm drill shank.
    The idea is to use the 4th axis of the CNC and cut vertically the teeth on a bias.
    From the 3D model above I have sketched just for fun, I made a 2D drawing, extracting the exact shape between two teeth.
    That will be the profile for my D bit.
    I start by rough grinding by hand the profile of the D bit, so that the CNC will do only a finishing pass.
    Checking the rough profile with the drawing.
    After computing the tool path from the 2D CAD drawing, the CNC does perfectly the job.
    The bit used is a 1/8" diamond grinding bit. The D bit is hold in the 4th axis' chuck, but it doesn't move.
    A little pass on the diamond stone to remove the burr
    Then I prepared a blank for the new gear. It's turned on the lathe out of POM-C.
    The key way is also cut on the lathe simply using the carriage.
    I gave it a temporary shaft just to hold it in the chuck.
    And I computed the G-code for cutting this part using the 4th axis to index the 37 teeth.
    But this acetal material is nightmare to cut with a single tooth cutter and it leaves a mega burr.
    The first rotation (3 passes per tooth) yields this nice black flower ...
    So I modified a bit my program to enlarge the travel on each tooth and had to play and replay it several times ...
    And I obtain this ugly thing ...
    After much much time spent scraping and cleaning up each tooth, I decided it was good enough and here is the final product.
    This is far from being a piece of art, but it turns out it works !!
    Now my milling machine is working again, I think I will try to make a new aluminum one, and instead of a fuse gear, I plan to use a fuse key, it may be less complicated to fix if it fails.
    Next time, I will try to use the module bit horizontally, as a mill profile on a shank, like can be seen on this image:
    I must give credit to this site https://thebreizmaker.wordpress.com/usinage-de-pignons/ for the idea of how to shape the tool using the CNC and a diamond bit.
    (sorry, I was a bit long ...)
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 15 Users Say Thank You to Christophe Mineau For This Useful Post:
    baja (Dec 5, 2020), Carnel (Dec 5, 2020), DIYer (Dec 5, 2020), emu roo (Sep 30, 2025), GKK (Dec 6, 2020), Home-PC (Dec 6, 2020), Jon (Dec 4, 2020), metric_taper (Dec 4, 2020), mklotz (Dec 4, 2020), mwmkravchenko (Dec 5, 2020), NortonDommi (Dec 5, 2020), olderdan (Dec 5, 2020), sacco1 (Dec 5, 2020), Scotsman Hosie (Dec 4, 2020), YOUCARS (Dec 9, 2020)
    Marion, Iowa
    metric_taper's Tools
    Did you have any issues with the 4th axis 3 jaw chuck concentricity?
    Jul 2014
    France, Brittany !
    mmmh, nothing noticeable, it seems to turn round enough, but I must admit I have not measured it yet, I will do.
    Did you have any bad experience about that ?
    Cheers !
    Christophe
  5. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Thanks Christophe Mineau! We've added your Mini Mill Gear Replacement to our Machining category,
    as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
  7. The Following User Says Thank You to DIYer For This Useful Post:
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    FWIW, if you made a metal gear you could use a plastic or soft metal "fuse" (shear) key.
  9. The Following User Says Thank You to katy For This Useful Post:
  10. #6
    Jul 2014
    France, Brittany !
    Quote Originally Posted by katy View Post
    Yep, that's what I just said at the end
    Cheers !
    Christophe
  11. The Following User Says Thank You to Christophe Mineau For This Useful Post:
  12. #7
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    Quote Originally Posted by Christophe Mineau View Post
    I musta missed that part
  13. The Following 2 Users Say Thank You to katy For This Useful Post:
    Christophe Mineau (Dec 5, 2020), emu roo (Sep 30, 2025)
  14. #8
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    That looks like it would benefit from a metal gear with a 'torque hub' as is fitted to some Mercury outboards but in miniature. The spare parts problem is more that importers only want to sell complete machines, don't want to stock spares and refuse to say who the manufacturers are. These importers are the same ones that bring in a reasonable to good quality machine and when a market is established either change suppliers or downgrade the model specs for a cheaper purchase price that is not passed on to the customer.
    Excellent write-up . Always a pleasure to see your work.
  15. The Following 2 Users Say Thank You to NortonDommi For This Useful Post:
    Christophe Mineau (Dec 6, 2020), emu roo (Sep 30, 2025)
  16. #9
    Jul 2016
    That is why I like V belt drives They slip when overloaded and usually much quieter. Have left the spindle lock pin on in my mill occasionally no bad results and no belt damage so far.
  17. The Following 2 Users Say Thank You to tooly For This Useful Post:
    Christophe Mineau (Dec 7, 2020), emu roo (Sep 30, 2025)
  18. #10
    TheElderBrother's Avatar
    Sep 2019
    The Land of Cotton
    I'm lucky if I can change a light bulb without breaking it off in the socket. This is some wizard-level stuff.
  19. The Following 2 Users Say Thank You to TheElderBrother For This Useful Post:
    Christophe Mineau (Dec 7, 2020), emu roo (Jan 8, 2026)
