Thread: Bi-directional CNC machining - GIF
    May 2024
    Bi-directional CNC machining.
    5-Axis CNC milling aluminum - GIF
    CNC bandsaw - GIF
    CNC grinding a medical drill bit - GIF
    CNC laser welder - GIF
    CNC lathe in action - GIF
    albertq (Apr 13, 2026), emu roo (Nov 19, 2025), nova_robotics (Nov 19, 2025)
    Sep 2018
    nova_robotics's Tools
    You can do it. It's fine. A little bit more tool wear and a little bit more heat, but it's alright. Just make sure you use climb milling for the finishing pass to improve the surface finish and reduce chip welding.
    It's just a checkbox in Fusion if you want to mill both ways.
    I usually mill both ways on my manual mill. I have it tuned up so it's tight as a drum so it can mill in either direction. Normally you should shy away from climb milling on a manual mill. If there's slop in your table you'll break end mills and ruin parts. It's surprisingly little work to tune up a mill. I don't know why people run their gear with slop in the x and y axes.
