Thread: Bladesmith tongs from Harbor Freight Oil Filter Wrench
    DocChuck's Tools
    I made a set of tongs out of a Harbor Freight Oil Filter Wrench and some scrap steel angle iron and flat bar. First, I filled in the slip joint with a TIG welder. Now it functions more like simple pliers. Then I heated up the ends of the tongs to bent them to further close the gap, leaving enough room to grab a ¼" x 2" farrier's rasp file. I use these worn out rusted files as tool steel to repurpose and forge them into knives and other cutting tools.
    Then I welded to pieces of 1" angle iron together to form a U-shaped channel that was just wide enough to accept a 2" rasp. Next I cut piece of the channel and welded it to the end of the modified oil filter wrench. Next,I cut a 1" length of 2" flat stock and welded it to the opposing end of the modified wrench. Once done, I checked the fit and grasping angle. Although it can grab a wide array of thicknesses...it is best suited for ¼"x2" farrier files.
    Bladesmith tongs from Harbor Freight Oil Filter Wrench-12240081_10156270998840182_7214271492571512069_n.jpgBladesmith tongs from Harbor Freight Oil Filter Wrench-12274453_10156270998665182_694519498239653468_n.jpgBladesmith tongs from Harbor Freight Oil Filter Wrench-12274506_10156270998690182_1579347067523182818_n.jpg
  2. The Following 11 Users Say Thank You to DocChuck For This Useful Post:
    Andyt (Jul 14, 2019), Arcadia (Apr 24, 2017), C-Bag (Nov 26, 2015), emu roo (Apr 17, 2025), Jon (Nov 20, 2015), kbalch (Nov 20, 2015), MetalDesigner (Nov 26, 2015), Paul Jones (Nov 20, 2015), PJs (Nov 20, 2015), rlm98253 (Nov 10, 2017), Scotsman Hosie (Jul 14, 2019)
    Thanks DocChuck! We've added your Bladesmith's Tongs to our Forging and Casting and Knife Making categories, as well as to your builder page: DocChuck's Homemade Tools. Your receipt:
  4. The Following 2 Users Say Thank You to DIYer For This Useful Post:
    emu roo (Aug 1, 2025), tuchie (Nov 12, 2024)
