HomemadeTools.net Members
Thread: Bolt Paint Rotisserie
    Jul 2017
    Port Elizabet, SA
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    garage nut's Tools
    On the MG forum I was told that originally the bolts securing the Tub to the firewall should be body color. I was saving all the bolts and nuts to have them plated. There are 18 of them so each one must be sandblasted, primed and then the top coat. fortunately black so a rattle can can do the job.
    So a rotisserie would be nice I was given a few broken micro wave ovens and one of the nice parts coming out of a micro is the motor turning the plate inside.
    Another nice part was the bracket that holds the light. It is nicely angled at 45 deg. Also an old stove on/off switch was easily secured with a cable tie.
    As you can see 240 V and rotating at about 5 rpm - Perfect Even the 240V mains lead is from the old Micro wave.
    A piece of 8mm fuel hose and a hose clamp to secure to 6mm motor shaft and the 5/16" bolt is just a nice fit to stay in place while being painted.
    I am sure this little aid will be used again.
    Advertisements
  2. #2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Advertisements
    Thanks garage nut! We've added your Bolt Rotisserie to our Painting category,
    Advertisements
    Post your reply!
    eBooks for Supporters
  3. The Following User Says Thank You to DIYer For This Useful Post:
    rlm98253 (04-10-2020)
