Results 1 to 4 of 4
Thread: Borehole widening backreamer - GIF
    Borehole widening backreamer.
    hemmjo's Tools
    I thought they typically pull a pipe or conduit in behind the reamer. If not there is a good possibility the bore will collapse after the reamer is pulled through.
  3. The Following 2 Users Say Thank You to hemmjo For This Useful Post:
    Frank S (Dec 3, 2022), Ralphxyz (Dec 7, 2022)
    If not, then they would at least have a swivel and a cable attached to the back eye on the reamer. I've recently made a few reamers and pipe pullers for a local contractor. He says you never want to leave a blank bore hole if it can at all be avoided
    mr mikey (Dec 4, 2022)
    Supporting Member mr mikey's Avatar
    May 2022
    Michigan
    mr mikey's Tools
