Thread: Boring Bar Tool Post for Sherline Lathe
    jjr2001's Tools
    Working on my tooling for the new shop and you always need a slick way to hold a boring bar. I had a set of vintage Clark Boring bars and thought they would be great on this small lathe for model work. After checking out the Sherline web site I found what I was looking for and proceeded to the shop to make them. I like the rocker tool post for the Sherline. It allows easy and quick (almost QCTP quick) change out of your cutting tools and the boring tool holders do the same. I made two. One for 3/8" bars with a 1/4" sleeve so I could also fit in the 1/4" Clark. Made another one that was for the 3/16" clark.
    You will see some unused holes where I had the idea to make one holder with two different holes for holding the bars but it was drilled oversize so I abandoned that idea and ended up with the bushing. The idea would work if the boring bar hole was drilled and reamed the correct size!
    Maybe I will build a new one later with the two bar capability.
    For these tool posts I did not use the Sherline extended T-nut, just used the standard one and I don't see why it won't do a good job.
    Cheers, JR
    Attached Thumbnails Attached Thumbnails Boring Bar Tool Post for Sherline Lathe-img_1951b-copy.jpg   Boring Bar Tool Post for Sherline Lathe-img_1953b-copy.jpg
  2. The Following 4 Users Say Thank You to jjr2001 For This Useful Post:
    Jon (Apr 28, 2018), PJs (Apr 30, 2018), rossbotics (Apr 28, 2018), Seedtick (Apr 28, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Looks good, they'll work just fine
    Comments are always welcome
    Doug
  4. The Following User Says Thank You to rossbotics For This Useful Post:
    jjr2001 (Apr 29, 2018)
    Thanks jjr2001! We've added your Boring Bar Tool Post to our Machining category,
    jjr2001 (May 1, 2018)
