Thread: Brad point drill conversion jig - video
    Brad point drill conversion jig. By JSK-koubou. 6:28 video:
    Electric hand planer rig system - video
    Drill bit sharpening jig - video
    Sanding dust table - video
    88 Best Homemade Sanding Tools eBook
    Vacuum clamp - video
    Router table from LCD monitor - video
    32 Plans for Homemade Router Tables
    Paint spray can trigger handle - video
    Doweling jig from used jigsaw blades - video
    Sandblasting cabinet - video
    Sandblaster - video
    Rubber band clamp modification - video
    Panel saw - video
    Sanding block - video
    Air hose reel - video
    Electric plane angle adjustment jig - video
    Splined miter joint jig - video
    Copy lathe - video
    Simple wire bender - video
    Universal sharpening jig - video
    Foldable painting booth - video
    Simple drum sander - video
    Electric caulking gun - video
    Aluminum frame circular saw guide - video
    Power lead container - video
    Featherboard from cutting board - video
    Center finder - video
    Quick corner clamp - video
    Wooden edge clamp - video
    Linear guide fence for router table - video
    Router table - video
    Line laser for panel saw - video
    Extendable circle cutting router jig - video
    Bench grinder tool sharpening jig - video
    Homemade aluminum frame and wood workbench - video
    Homemade simple sandblaster - video
    Homemade height gauge for circular saws and routers - video
    Homemade jigsaw table - video
    Homemade drum sander - video
    Homemade magnetic drill guide - video
    Homemade corner clamp from scrap plywood - video
    Homemade parallel link planer jig - videos
    Homemade router sub-base and centering cone - video
    Homemade metal nibbler stand - video
    Homemade angle grinder sliding cutting jig - video
    Homemade table saw push block - video
  2. The Following 2 Users Say Thank You to Jon For This Useful Post:
    johncg (Jul 23, 2021), lassab999 (Jul 21, 2021)
    Mar 2013
    Perth Western Australia
    Peter Sanders's Tools
    Not a real brad point drill bit.
    This IS NOT a brad point drill. This is a normal drill with the cutting edges ground in reverse angle. While it "MAY" provide an improved cutting action over the normal "metal working" drill, it will not provide a hole as clean as a proper brad point drill.
    I purchased a Bordo brand drill bit that was labelled as a brad point drill bit. It was ground the same as you show in the video. (this was of course not a proper brad point drill bit).
    While realising this was not a brad point drill bit, I thought I would try it anyway. I used the drill to create holes for adjustable shelving in an MDF board that had a laminate surface. As most of the holes were visible, they needed to look good. This Bordo drill bit, a pretend brad point drill bit caused chipping of the laminate an the hole edges.
    A real brad point drill bit has spurs at the outer end of the cutting edge. These spurs score/cut the outer edge of the hole prior to the "real" cutting edge starts to remove material. I returned (for a full refund) this pretend brad point drill bit and explained to Bordo their misleading label. The retailer also considered the Bordo drill bit as a brad point drill bit, it is not. The images below, clearly show the difference.
    I then purchase a REAL brad point drill bit from a specialist supplier. The drill bit purchased looked like the first image.
    Name:  brad point drill tip.jpg
Size:  2.0 KB Name:  brad point drill tip2.jpg
Size:  8.4 KB Brad point drill conversion jig - video-brad-point-drill-tip3.jpg
    Using a THIN grinding wheel with your jig may produce an image similar to the first image and COULD then be used like a real brad point drill bit.
    Best wishes
