I made this Brake Drum Puller with a 16-17” reach from scraps I found in the barn. Needs a few modifications but seemed to work relatively well. https://youtu.be/Cjs0rABUFbM
Thanks YanasaRanch! We've added your Brake Drum Puller to our Brake category,
as well as to your builder page: YanasaRanch's Homemade Tools. Your receipt:
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-brake-drum-puller-9"> <img src="/uploads/223816/homemade-brake-drum-puller-9.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-brake-drum-puller-9">Brake Drum Puller</a> <span> by <a href="http://www.homemadetools.net/builder/YanasaRanch">YanasaRanch</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/puller'>puller</a>, <a href='http://www.homemadetools.net/tag/brake-drums'>brake drums</a> </div> </div> </div> </div>
many may scream foul but i've have been where you are several times over the decades, some times a relief cut is nessisary at the drum hub hole a short torch cut 3/4 to an inch cut from hub between lugs toward drums outer dia.
this allows drum to release hub. not ideal but failure or runnin with out brakes can kill or cripple or just smash things.
al
