Results 1 to 7 of 7
Thread: Brilliant Tapping Trick on the lathe or mill
    Supporting Member anthonyget's Avatar
    Oct 2019
    Kelmarsh, UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    anthonyget's Tools
    Many of you will know this trick, but I only learned it recently. I read about it in an article or letter in Model Engineer's Workshop magazine and had to try it. I was sick to death of breaking taps and this is a fantastic way of not breaking taps and getting a perfect thread every time.
  2. The Following 10 Users Say Thank You to anthonyget For This Useful Post:
    Altair (09-29-2020), Carnel (09-23-2020), Corm (09-23-2020), H.L (09-23-2020), Home-PC (09-23-2020), Jon (10-14-2020), nova_robotics (09-22-2020), Scotty12 (09-22-2020), Sleykin (09-22-2020), trigger (09-27-2020)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hemmjo's Tools
    That is a very good idea. The De-Speeder as shown may be difficult to find. But most everyone as an old rechargeable drill. I have collected at least 5 in a box from over the years. All of the ones I have use planetary gears to "de-speed" the little high speed motor and multiply torque for the drill. While it would take a little modification to make one into a tapping tool as show, all the important parts you need are there.
  4. The Following User Says Thank You to hemmjo For This Useful Post:
    Supporting Member Sleykin's Avatar
    Oct 2017
    Medford, Oregon USA
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sleykin's Tools
    IIRC the de-speeders were intended so you could use an OG drill for running screws in. Before variable speed reversible drills. I think I have one around here with 2 rings on it. one makes it go forward and the other backs it off.
    I also have a couple tapping heads for the drill press and mill, might work well on the lathe too?
    Oct 2019
    Kelmarsh, UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    anthonyget's Tools
    Thanks hemmjo. They do come up on Ebay quite regularly, at least here in the UK, but I always assumed, maybe wrongly that Rawlplug was a US company. Also, your idea sounds very sound.
    Oct 2019
    Kelmarsh, UK
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    anthonyget's Tools
    Quote Originally Posted by Sleykin View Post
    Thanks for explaining. I will add your info to my video's description if that's ok.
  8. The Following User Says Thank You to anthonyget For This Useful Post:
    Sleykin (09-23-2020)
    Oct 2017
    Medford, Oregon USA
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sleykin's Tools
    Sure... although that is just my memory. I know I used them for screws before I had the VSR drill.
  10. #7
    Altair's Avatar
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Thanks anthonyget! We've added your Lathe Tapping Technique to our Machining category,
    as well as to your builder page: anthonyget's Homemade Tools. Your receipt:
    Post your reply!
    eBooks for Supporters
