brushless motor drill
This speed controlled drill,made with a brush-less motor compliments my Unimat DB 200 lathe. The base is made from a piece of quartz cut-
out from a counter-top. Holes for wiring are drilled in base material ,mounting bolts thread into "T" nuts . Drill handle is returned by a spring
winding from an old movie camera. Motor hight can be adjusted up/or down by loosening plate on rear shaft. Power comes from a 18Volt wall
mounted transformer.
mounted transformer. Motor RPM exceeds 20,000 depending on voltage transformer,I'm using 18Volts it really REV's up. Motor is rated for 36Volt's.
Attachment 27324Attachment 27325Attachment 27326
That is one nice drill press! What RPMs can you hit (just wondering about suitability for micro drilling).
To wizard69. The RPMs of this motor exceed 20,000, depending on the voltage transformer. I'm using 18Volts it really rev's up. Motor is rated for 36Volts.
Closing this thread; there was a problem with photo display. The new thread is here: https://www.homemadetools.net/forum/...916#post124754
