Results 1 to 10 of 10
Thread: Building concrete slab houses - GIF
Hybrid View
    May 2024
  2. The Following 5 Users Say Thank You to ToolTalkBot For This Useful Post:
    albertq (May 29, 2024), mwmkravchenko (May 28, 2024), nova_robotics (May 28, 2024), odd one (Jun 2, 2024), Ralphxyz (May 28, 2024)
    Perth Ontario Canada
    Easy when you don't need to heat in the winter. Southern China they usually don't have heating. Even though its about as far south as Brownsville Texas. The Sea does make up for some of it. But it get really cold with the high humidity like around coastal Washington State.
    Mark
  4. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    Dec 2016
    Ralphxyz's Tools
    Are the walls insulated? Ineresting but plastering the walls is a slow process.
    Supporting Member wood_1's Avatar
    Oct 2023
    Edmonton
    I guess they used stranded wire for the ease of running it through conduit, I like the way they terminate the connections (not being an electrician or really any training on that stuff)...
    Dec 2016
    Ralphxyz's Tools
    I'd like to see more about how they terminate the wiring.
    Aug 2012
    Australia
    desbromilow's Tools
    if you're referring to the "bootlace ferrule" they used to terminate, I've been told by my sparkies not to use them in power applications, just instrumentation applications. Apparently the thinner walls of the bootlace ferrules will creep, unlike the proper crimp terminals used in power applications.
  9. #7
    Apr 2014
    Gadgeteer's Tools
    Quote Originally Posted by desbromilow View Post
    Not to worry... the crimped ferrules were depressed by the connector screws, thusly, eliminating creep.
    Supporting Member Duke_of_URL's Avatar
    Aug 2018
    Texas
    Great concept for here in Tornado country, Texas, but only if the concrete was made correctly. As previously mentioned, the interior walls would need to be finished out or you'd feel like being in a "prison" with windows. Not sure if this construction would sell that well.
  11. #9
    Dec 2016
    Ralphxyz's Tools
    I do not see how the walls or the slab is fastened down I think a srong wind could blow it down!
  12. #10
    Gravity is a long term solution. It doesn't deteriorate with time.
